Old 04-14-2016, 04:09 PM   #1
Front and rear sway bar? Or front only?
I'm upgrading the suspension on my 3051S. I want to add Bilstein shocks all around and Hellwig front sway bar. I'm wondering if i should put a Hellwig in the rear while I'm getting the work done. Seems like Ride-Rite system should provide necessary sway reduction and after 15k miles, seems like my issues are front sway and overall jarring from the shocks (esp. in rear).
Thanks for your feedback.
2016 Forester 3051SF
MMulcahy is offline   Reply With Quote
Old 04-23-2016, 09:44 AM   #2
I did the front and rear sway bars from Hellwig, made a heck of a difference in the handling. On a trip up to Oklahoma the wind was horrible and going 50-55 was the max we could do without feeling like the rig was getting out of control.
After the sway bars, 60-65 in the same type of wind was no problem at all and everything feels great.
Your mileage may vary, but the money was well spent for us.
We have a 2012 3011DS.
JSowles is offline   Reply With Quote
Old 04-25-2016, 11:06 AM   #3
thank you!
Do you know the part number for the rear sway bar? I have a 2015 chassis, and no one shows it for this model year. I'm guessing it is the same as the 2014.
Old 04-29-2016, 03:32 PM   #4
I just made a post regarding the changes we made to our Forester 3051S. You might find that helpful.
BIKERMHA is offline   Reply With Quote
Old 04-30-2016, 12:32 PM   #5
vwexpert's Avatar
I just ordered front and rear Hellwig sway bars from amazon. 7180 rear / 7718 front. The rear air bags mainly act as helper springs for weight - they do very little for sway from wind / trucks / uneven roads / etc. My Bilstein shocks and damper helped a lot...I hope these sway bars compliment the shocks.
Jim
1971 20ft fireball (too small)
1987 27ft Tioga (bad brakes / tires)
1998 36ft Discovery (rattles / air leaks)
2005 37ft Monaco Knight (lemon Lawed)
2008 40ft Monaco Diplomat (too big)
2016 Forester 3011 (ordered June 8th - Born Aug 6) IT'S HERE
vwexpert is offline   Reply With Quote
Old 05-07-2016, 09:17 PM   #6
I'm having the rear anti sway bars done first and will then determine if I need the front ones installed. I'm going with Roadmaster brands.
toddlafond is offline   Reply With Quote
Old 05-08-2016, 01:07 PM   #7
vwexpert's Avatar
I believe the reason to do all 4 shocks and / or front and rear sway bars together is to balance out the handling and steering. Having stiffer rear sway bars than the front will effect the steering through corners.
Jim
Old 05-09-2016, 08:26 AM   #8
Jim,
Thanks for that info. I never thought of that. I asked a few technitions and they said to do the rear first but that does make allot of sense.
sway
