Old 08-01-2019, 08:34 PM   #1
Bonjoey's Avatar
Front cap marker lights
Question, 1) how do you replace/remove these marker lights?
2) should I sealed these with caulk to avoid any leaks?
2019 FR Sunseeker 2650S E450SD
Bonjoey is offline   Reply With Quote
Old 08-01-2019, 10:11 PM   #2
There is a rubber grommet around the edge of the hole in the fiberglass and the body of the light is a smooth cylinder that is pressed into the grommet. The chrome trim piece covers the rubber grommet. I also wanted to be sure they were well sealed and found that I could not pull them out very far because there was not much slack in the wires. I ended up pulling out a bit and putting some clear sealant around the light body and pressed them back into place.
2017 Forester 2861DS
towing 2015 Jeep Rubicon
fobagbob is offline   Reply With Quote
Old 08-04-2019, 04:21 PM   #3
Rkloud9's Avatar
It is amazing how much water can come in through those lights if they leak. It may not be the prettiest solution, but I used lots of clear silicone sealer to stop mine from leaking.
Bob & Cynthia
2017 SunSeeker MBS 2400W
Rkloud9 is offline   Reply With Quote
Old 08-04-2019, 04:48 PM   #4
Bonjoey's Avatar
So still better to seal it even though the lights are tight?
Old 08-04-2019, 09:34 PM   #5
Rkloud9's Avatar
Well, if it ain’t broke, don’t fix it. We spend a lot of time in our 2017 SunSeeker 2400W (18 months in the last 3 years, 47000 miles). Those lights did not leak until they did, driving on I10 across Louisiana in one of the heaviest rainstorms we have ever experienced. The leak soaked the headliner in the top of the cap, and flooded one of the led lights, knocking out about 1/2 the diodes. There was water sloshing around in the lower part of the cap that dripped into the cab where the sun visors are attached, and this continued for several days. It took at least a week before the headliner dried out. Luckily, no stains. The silicone is clear, so the lights still work. Before we hit the road this fall, I can assure you we will dab some more on those lights.
Bob & Cynthia
light, sunseeker
