Old 10-06-2015, 03:23 PM   #1
Creativepart's Avatar
Front Curtain?????
Anyone here figure out why the front curtain on the Forester has velcro dots that go down at an angle rather than straight across the bulkhead??
It makes no sense.
All the plastic velcro dots run in a straight line until they get to the bulk head and then they angle down in an odd way.
What's the thinking here? What's the correct way to do this?
ID:	90817   Click image for larger version
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 10-06-2015, 03:59 PM   #2
vwexpert's Avatar
We were wondering the same thing.
1971 20ft fireball (too small)
1987 27ft Tioga (bad brakes / tires)
1998 36ft Discovery (rattles / air leaks)
2005 37ft Monaco Knight (lemon Lawed)
2008 40ft Monaco Diplomat (too big)
2016 Forester 3011 (ordered June 8th - Born Aug 6) IT'S HERE
vwexpert is offline   Reply With Quote
Old 10-06-2015, 05:53 PM   #3
Boso's Avatar
Seems like that's the only way to get complete privacy when pulled tight but we only used one time until I could get the window cover ordered probably never use again
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 10-06-2015, 06:00 PM   #4
vwexpert's Avatar
I purchased the fancy ft window cover - you can see in at night when the lights are on.
Old 10-06-2015, 06:06 PM   #5
Boso's Avatar
Yes you can those are for the rv's with the electric shade but they started selling to all classes and people don't know that until they look thru somebody's at night then they realize it's not good
Old 10-09-2015, 11:31 AM   #6
There is another dot lower down. When it is attached you have privacy. Yrs you can see through. I bought room darkener curtains and replaced . total darkness.
tadlockjp is offline   Reply With Quote
Old 10-09-2015, 12:10 PM   #7
Yes, there is another dot down lower in an even more obtuse location.
The fact is, the curtain is a rectangle, but the velcro dots are not set up to accommodate a rectangle.
I'd love to hear from one of the factory reps about this item - how does the factory think this works and why do they do this this way???
Old 10-09-2015, 02:30 PM   #8
Must have changed the location of the Dots, my 2012 has them lined up straight. If they aren't where you want them, just add them where you do. You could relocate but you would end up with a little hole in the vinyl, probably hard to see when the material relaxes and returns.
For us I installed extensions to the overhead bunk curtains so we just slide the front closed when needed and don't use the velcro curtains. The extended cab curtains also work well to close off the cab while driving in hot or cold conditions as the chassis heat and A/C only need to maintain the cab.
ATVer is offline   Reply With Quote
Old 08-13-2018, 05:30 PM   #9
CruisingCajun's Avatar
Here we are some 3 years later and my 2018 has the same Velcro layout. Makes no sense to me.
CruisingCajun is offline   Reply With Quote
Old 08-13-2018, 05:41 PM   #10
Duckogram's Avatar
C-N-Azow you dredged up a 3 yr old thread, you might want to dredge up my post on how to make a curtain that darkens, insulates and does make sense.
If you want more screw on velcro “dots”, I have a bunch of tan ones that I removed.
Note: The curtain mod will work on Class C models with the ceiling mount track instead of the wall mount.
ILB ( | )
