Old 10-28-2018, 06:25 PM   #1
Bus Driver
Deaver's Avatar
Front Overcab Clearance Light Cover(s)
Since this subject comes up from time to time for those of us that have an "older" Sunseeker or Forester, I thought I would pass this on.
The clearance lights were manufactured by a company called Glo-Brite who is no longer in business. Few parts suppliers have parts by now but, every once in a while they appear. They look like THIS
Yellow Lense - Click HERE
They may be pricey but available.
I carefully removed each lens and inspected it for cracks and replaced as necessary. Because it takes an almost acrobatic skill to deal with these lights, I decided to "modify" them as follows
I purchase these LED's Click HERE
You want to use this style as it uses a miniature PC Board for the contacts. Don't use the plastic base types as they will not last due to heat (I know)
Before inserting the LED assembly, put a smear of Permatex dielectric grease on the board portion to keep corrosion in check
Apply a small bead of RTV silicon adhesive on the inside edge of the lens before reapplying. This will keep water intrusion to a minimum.
I completed this mod three to four years ago with no issues
2012 Forest River Forester 25651S - The Magic Bus
Just trying to be the person my Dog thinks I am
Deaver is offline   Reply With Quote
Old 10-31-2018, 11:06 AM   #2
Excellent advice. Thank you!
Mach428 is offline   Reply With Quote
cover, light
