Old 12-24-2018, 07:51 PM   #1
papap's Avatar
Front slideout
My front slide out is having a hard time going in or out. I guessing it needs lubrications. Anyone have instruction or a video on how and where to oil it at?
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 12-24-2018, 09:07 PM   #2
There are many different kinds of slides and different procedures for all.
Do you know what kind of slide mechanism you have?
Days Camped: '16=46 '17=30 '18=51 '19=32
Old 01-08-2019, 08:45 PM   #3
papap's Avatar
I’ll check and repost.
Old 01-08-2019, 09:48 PM   #4
Coach
If you see any tracks or gears along or under the slide, start with those. Personally I use a dry lube, but I'm sure like everything else, everyone has an opinion on what's best. Have you lubed your slide seals as well? 303 protectant or something similar works well for that. If lubing everything up doesn't do the trick, check your batteries. Slide motors draw a lot of power. A sub par battery will cause issues.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 01-08-2019, 10:49 PM   #5
Jayhawker
Jayhawker's Avatar
Schwintek slide out lube video
http://lci1.com/support-in-wall-slide-outFound this on YouTube may be of some help if you have this slide out system.
Jayhawker is offline   Reply With Quote
Old 01-10-2019, 08:29 AM   #6
Citrus County, Fl.
GL1800Rider's Avatar
https://www.amazon.com/CRC-03044-Lub...pray+lubricant
I use CRC 03044 Dry PTFE Lubricating Spray. This will not attract dirt like some of the other types will.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 01-15-2019, 11:03 PM   #7
Garrette's Avatar
Front slideout
If your outside and inside seals have not be conditioned with a seal conditioner the slide will drag. Keep the seals and flaps soft and pliable.
Also, ensure your batteries are fully charged. Less than fully charged may cause a slow slide.
FYI, To access the gear mechanism loft the front of the couch up. It just hangs over a bar. Than you can raise the rubber flap to access the drive system.
This is based on my 2014 3170 very similar to your 3171.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 01-19-2019, 07:00 PM   #8
papap's Avatar
Batteries
Would it still do it with the camper plugged to shore power?
Old 01-23-2019, 11:52 AM   #9
Garrette's Avatar
Did the OP get their problem resolved?
Old 01-23-2019, 12:07 PM   #10
papap's Avatar
No fixed
Have not had a chance to look at it. Going to try later today.
slide
