Old 07-28-2015, 06:07 PM   #1
benagi's Avatar
Furnace and A/C running at same time
Just tried our furnace for the first time, and when it came on the A/C came on at the same time. Only happens when on shore power or generator running. Any ideas? We think maybe thermostat wired incorrectly.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 07-28-2015, 06:45 PM   #2
2012 Solera
Several threads on this. Most likely the aircon compressor isn't running - just the fan. Circulates the air (heat). If you prefer the fan in the air conditioner off when using the furnace, as most of us do, go to the thermostat, select "fan", use the "+" and "-" buttons to select "Auto", then re-select heat. With the fan set to auto, it will stay off when the furnace is used and will cycle with the compressor when the aircon is used.
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 07-28-2015, 06:56 PM   #3
benagi's Avatar
Thx Jleising, we will give that a try.
1968 tent trailer
1985 Jamboree 23 ft
Old 07-29-2015, 04:46 PM   #4
I can confirm. Yes, just the fan from the ceiling A/C is running to help circulate the air. I rarely use our furnace - preferring the heat pump for most heating needs so I have not tried the option of selecting the A/C fan OFF when on furnace.
Bobby
bgilly is offline   Reply With Quote
Old 07-29-2015, 04:56 PM   #5
Ford Idaho's Avatar
Never mind....
Old 07-30-2015, 11:44 AM   #6
FIVE2MH's Avatar
bgilly:
When using the Heat Pump, does it run on electric, not Propane?
2015 Forester MBS 2401R
No Toad
FIVE2MH is offline   Reply With Quote
Old 07-30-2015, 12:07 PM   #7
Originally Posted by FIVE2MH View Post
bgilly:
Right, electric only. It reverses the cycle of the air conditioner to heat the air inside rather than cool it. Works good for heat down to around 38 - 40 degrees outside air temp..
Bobby
Old 07-30-2015, 01:42 PM   #8
Some digital thermostats have a programmable fan function: choices are AU (auto), LO or HI. If you program it on LO or HI the A/C fan will come on with the furnace. If you program it on auto, the furnace will not activate the fan.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 07-30-2015, 02:03 PM   #9
benagi's Avatar
That's the exact thermostat we have. JLeising above mentioned exactly what you said. That must be the problem we had then. I had the thermo set to Lo on the fan. Will set to auto the next time we fire up the furnace. Thx for your feedback Big Vic.
1968 tent trailer
1985 Jamboree 23 ft
Old 07-30-2015, 02:05 PM   #10
FIVE2MH's Avatar
Thanks for confirming...��
No Toad
furnace
