Old 12-01-2013, 09:13 AM   #1
Furnace and ceiling unit confusion
We are currently in Gatlinburg camping and with night temps rather chilly we of course are using the furnace. However when I turn it on the ceiling A/C unit comes on too as if I am using the heat pump function which I am not! It blows very cool air. Not as cold as outside temps but very cool. And it stays on!
Help????!!!!
DennyH is offline   Reply With Quote
Old 12-01-2013, 09:18 AM   #2
jtstromsburg's Avatar
Adjust the thermostat from hi or low to auto. See if that helps
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 12-01-2013, 09:20 AM   #3
simplyrwc's Avatar
In my unit when the furnace is on the overhead fan turns on to recirculate the air. You should be getting warm air from the floor vents and the overhead vents should start to get warm once the cabin starts heating up. Unless I am mistaken too then I'm eager to hear the answer.
2004 V10 4X4 Excursion
2014 FR Wildwood 32BHDS
2013 Days Camped 14
simplyrwc is offline   Reply With Quote
Old 12-01-2013, 09:41 AM   #4
Herk7769's Avatar
Sounds like your fan control (thermostat) setting is wrong.
Is it a digital model?
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 12-01-2013, 09:46 AM   #5
Herk7769- yes it is digital. I can't imagine the ceiling unit staying on all the time even when the furnace reaches temp and cycles off??
Old 12-01-2013, 09:54 AM   #6
simplyrwc's Avatar
Dug in a little more....from what I am reading there is three settings on the fan hi lo and auto as mentioned above. Go to fan and switch it to auto.
http://www.forestriverforums.com/for...fan-23706.html
2013 Days Camped 14
Old 12-01-2013, 10:24 AM   #7
Simlprwc- thank you!! Looks like that did the trick!!
Old 12-01-2013, 10:27 AM   #8
simplyrwc's Avatar
Jtstromsburg gets the credit. And we both learned something new today.
2013 Days Camped 14
