Old 11-13-2014, 04:13 PM   #11
GM
bclemens's Avatar
I don't recall the details, but I seem to think something like this happened and it was two different causes.
1. debris or dust in the line caused the regulator valve to freeze up.
2. Something with a check valve to something, They had to turn off the tank, wait a bit and then open it very slowly.
Or I could be recalling the complete wrong thing...but the 2nd one costs nothing to test.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 11-13-2014, 08:14 PM   #12
thanks to all that commented. I used bcclemens suggestion and it worked
jimrose is offline   Reply With Quote
Old 11-13-2014, 08:18 PM   #13
Could be flame sensor dirty. Take steel wool or light sanspaper and clean off any black or corrosion. Rhis also no cost. Id this does it easy replacement and not expensive. 2nd is limit switch make sure ALL heat vents open and nothing blocking airflow. Also make sure filter clean. Sounds more like limit than sensor but might as well check both.
USNMM1VETERAN is offline   Reply With Quote
Old 11-13-2014, 08:20 PM   #14
Opps sorry did not read part about stove flame. But never hurts to remind people to check filters.
Old 11-13-2014, 08:30 PM   #15
GM
bclemens's Avatar
Admin needs to add a "squirrel finds a nut" emoji. I was reaching back to the inner reaches of my mind. Almost got lost.
Old 11-13-2014, 10:51 PM   #16
Boss Hoss's Avatar
Possibly a bad thermo couple?
2013 Palomino 30ft. of Pure Bliss at 5400#-and then we have this 14 ft.Sea Eagle that I tote around for my wife and son.Michigan State Parks are The Best !:thumbsup
Boss Hoss is offline   Reply With Quote
Old 11-18-2014, 05:32 PM   #17
There is a way to "reset" the thermostat. We reset ours the first time we used the heat on our 3010 but that was two years ago and unfortunately I don't remember the sequence, perhaps someone could help out.
Chas69 is offline   Reply With Quote
Old 11-18-2014, 06:40 PM   #18
Boss Hoss's Avatar
Pull the fuse marked furnace-in the fuse box.Count to 10 and re-install.Done Deal.
furnace
