Old 01-20-2014, 06:17 PM   #1
Irish Reb's Avatar
Furnace Operation
There is probably a simple reason but I have not figured it out yet. We are testing out our Forester 2251LE and when running the heater, the blower fan from the AC unit (above) activates. The heater unit is working as we have heat coming from the floor area but I don't know why the blower fan from the AC unit runs. Is it supposed to or are we running improperly?
Irish Reb is offline   Reply With Quote
Old 01-20-2014, 06:43 PM   #2
Dave_Monica's Avatar
You need to set the fan control on the thermostat to Auto instead of Hi or Low.
Dave
Old 01-20-2014, 06:49 PM   #3
Furnace Operation
It's just as David said.
You can go to the Sunseeker forum, look for a thread updated on 11/14/12, entitled something like "AC fan runs when furnace is on" for additional info about this exact thing.
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
paulmlac is offline   Reply With Quote
Old 01-21-2014, 05:50 AM   #4
Dave
To elaborate a little...Use the on/off setting on your thermostat to highlight the "fan" setting. You will find the display showing "HI" or "LO". Use the + or - keys to change to "AU" (Auto). Now use the on/off setting to move to furnace and set temperature as desired. When the furnace turns on you will no longer have the AC fan running--just the furnace fan.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 01-21-2014, 07:12 AM   #5
On the flip, side, I could see that it might be useful to let the fan on (not on auto but on hi and lo) in some cases....it might help to push some of the heat up near the ceiling down...sort of like running a ceiling fan in the winter.
Of course, you'd want to have electrical hookups to do so...
jrwalkerpa1 is offline   Reply With Quote
Old 01-21-2014, 08:28 AM   #6
Irish Reb's Avatar
Thank you
Thanks, yes makes sense. Did what you suggested and it worked....
Old 01-31-2014, 01:43 AM   #7
Plain Old Member
We always left the blower on, at night anyway. 1, for the noise and 2 to circulate the heat around a little. Some of our previous units wouldn't let the roof fan run with furnace on, so I consider it a bonus.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 01-31-2014, 07:18 AM   #8
TURBS's Avatar
X2
TURBS
oc's buddy
furnace
