Old 12-22-2013, 01:36 PM   #1
Frank & Eve's Avatar
Furnace vs Heat pump ???
I am a bit confused about the heat pump. You have a furnace why a heat pump? Not sure when to use it or why. Yes I'm a newbie....appreciate any feed back.
Frank & Eve is offline   Reply With Quote
Old 12-22-2013, 02:36 PM   #2
jtstromsburg's Avatar
Heat pump uses only electricity. I have one at home and it saves money. I hear the RV heat pumps are good to about 40 or so f. Below that, you'll likely need to switch to furnace and/or portable heaters.
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 12-22-2013, 04:16 PM   #3
bend302's Avatar
Residential heat pumps have an electric coil internal to the air handler and will supplement the heat pump at low temps.
RV heat pumps installed on the roof generally have no supplemental electric heat and are designed to shut off somewhere south of 40 degrees. Then you need the gas furnace.
Also, for those systems that heat the basement storages and plumbing bays, only the gas does that. Because the heat pumps are on the roof, they cannot duct warm air to the storage bays.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is online now   Reply With Quote
Old 12-22-2013, 04:18 PM   #4
Witch Doctor's Avatar
Sent by me
X's 2 Consider yourself lucky to have both. I think all units should come with heat pumps..............
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-22-2013, 04:25 PM   #5
bubbles's Avatar
Just curious. Is your AC a heat pump or does it just have a heat strip?
Old 12-22-2013, 05:00 PM   #6
I wouldn't know...all I know is that on the thermostat there is a setting for Heat Pump and when that is on, heat comes out of the same ducts that the AC does. When the thermostat is set on furnace, heat comes out of the ducts at the bottom of the cabinets near the floor
Old 12-22-2013, 05:21 PM   #7
I checked into adding just a strip heat 5 kw. They make a kit to do it pretty easy except you have to add another stat wire. Then only thing I think a person can do is either tie on to one end and pull new wire or use the either the high or low wire from the a/c so you don't have to pull new wire could be a big problem if stapled trying to pull new. I never use the high blower setting it's to noisy but still have it on my list to do so I could use that. Just a Thought........
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-22-2013, 08:34 PM   #8
5kw? How much amp draw? A true 5 kw will draw 41 amps at 120 volts - well above the typical 30 amps service before you even account for the heat pump compressor running. You obviously meant 5000 btu which will draw about 13 amps. Add the amps of the compressor (14+) and you are at borderline of 30 amp service without room for the power converter to maintain the 12 volt stuff.
With power it's all about volts and amps. At 120 volt you have roughly 22 - 24 amps of reserve (you have the fixed draw range of the converter).
Run the electric element on the water heater (12 amps), electric for the refrigerator (5-5 amps), microwave (9 amps) you have to trade-off electric loads to keep from tripping the 30 amp breaker.
As for the question on the heat pump operation; don't think of it as heat like from your furnace. It is sufficient for heating when temps are 50 - 60 degrees with moderate humidity range. If humidity is higher the heat pump won't heat enough for creature comfort although it will raise the temperature.
Experiment with it - maybe even try supplementing with a space heater (although it too adds to the electrical load).
Bobby
bgilly is offline   Reply With Quote
Old 12-23-2013, 02:35 AM   #9
Bobby, you are right I meant 5000 btu, but the compressor will not kick on, the new control board that comes with it locks it out. So really you are only pulling 13 amps plus the blower motor amps. It's just a way to take the chill off noway that would give enough heat off for the unit. In the morning I turn on the fireplace, The intake is above that. Heat rises so it would add to the whole unit and not just the rear lounge area. I really do not camp in cold areas, but even in Goshen we needed it in the early AM. Thanks for the correction.
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-23-2013, 06:57 AM   #10
Bobby, you are right I meant 5000 btu, but the compressor will not kick on, the new control board that comes with it locks it out. So really you are only pulling 13 amps plus the blower motor amps. It's just a way to take the chill off noway that would give enough heat off for the unit..
That's interesting. I haven't researched adding a heat strip much although I have considered it. Typically in heat pumps, the heat strip runs with the compressor and that is how I thought it worked on RV heat pumps. In my head I was adding the 15000 btu of the heat pump and the 5000 btu of the heat strip for a total of 20000 btu - a considerable amount of heat.
A conversion for 5000 btu is about 1500 watts which is around 13 amps. This conversion is whether you use the strip heater or an electric space heater.
Bobby
