08-14-2014, 07:24 AM
Gap between rear slide on a 3170ds
Hi all,
I have a relatively large gap between the rear slide and the motorhome wall when the slide is pulled in. It is big enough for me to fit my fingertips in it. However the front slide is totally flush with the motorhome when pulled in. Is this normal to have space between a slide and the motorhome? I have attached a picture of what I am talking about. Thanks
08-14-2014, 09:57 AM
Not normal. This slide needs an adjustment and or a repair.
08-14-2014, 10:45 AM
That's strange...when I took it to the dealer for other repairs I pointed it out to him out of curiosity and he said that's normal. I guess I'll have to take it back.
08-14-2014, 11:08 AM
Does anyone know if there is a way to manually tighten the rear slide on a 3170? I know you can on the front slide but I wanted to see if tightening the rear slide would close the gap.
08-14-2014, 12:39 PM
My 3170 does this some times and I have found that using the slide out seal conditioner helps. You need to go to lippert components web site and watch the video on the schwintec slide system then you will understand your slide better. there is an adjustment but it is an electrical one regulating how much power you are sending to the motors.
08-14-2014, 12:55 PM
Commercial Member
Normal.
Those Schwintec slides have separate motors for each side and although linked they stop when they meet resistance. They tend to cut off at slightly different times based on resistance of each side.
As long as the bulb seal, seals completely there should be nothing to worry about. If that gap gets bigger, then you might want to have it looked at.
The old "above floor slides" were ram driven (in the bottom middle), so the bottom was tight, the top, not as much but you rarely saw it.
08-14-2014, 10:33 PM
At first from looking at your picture I thought the gap looked large too. However, I went out and looked at my 3170DS rear slide and I too can just slide my finger tips in their but only about an inch in until you get to the rubber gasket. Mines always been this way and is fine.
2011 Sunseeker 3170DS - 30,000 miles explored
08-14-2014, 11:59 PM
Same here. My front slide pulls in tight and clicks when it can not move any more. The rear just stops. Is that normal ? The front clicking?
08-15-2014, 06:53 AM
The front slide clicking is normal...mine does that too. It's a different kind of slide than the rear slide. I pull my front slide in until I hear it start to click.
08-15-2014, 07:41 AM
DMezzoprete your slide space is normal, its when it looks like this you have to worry!
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
08-15-2014, 08:22 AM
What happened here?
08-15-2014, 08:55 AM
After sending pic to factory and dealer, no one could give reason for cause, the bottom five screws stripped out of the wall, this happened within three months of ownership. The repair was to install new screws inbetween stripped out ones, so far holding.......
2014 Forester 3051s
2012 Sonic toad
08-15-2014, 09:02 AM
Commercial Member
Use rivets.
Th screws were the recommend installation method from Lippert. On the big slides, we prefer to add some big rivets. (lippert says we don't need it, your picture says better safe than sorry)
08-15-2014, 09:10 AM
Thanks for that info bclemens, the pic is of the factory screws stipped out, what size rivets would you reconmend and I will install myself, ( dealer just left stripped ones in and sealed overtop) Sorry to hijack this post!!!
2014 Forester 3051s
2012 Sonic toad
08-15-2014, 09:16 AM
Don't apologize jfrauts, this information is good to know!
08-15-2014, 09:21 AM
Commercial Member
I'll have to check with production on that one. Currently at 30,000 feet heading to Denver RV show.
08-15-2014, 09:26 AM
Thanks have a safe flight and good show
2014 Forester 3051s
2012 Sonic toad
08-20-2014, 02:08 PM
Hey bclemens hope you had a good show, any word on rivet size to replace stripped screws on my 3051s slide ( sitting at KOA camp ground thinking of mods to do when get home Cheers !
2014 Forester 3051s
2012 Sonic toad
08-20-2014, 02:13 PM
Commercial Member
1/4" expandable rivet. Not sure what they are running them on, but again Lippert says they are unnecessary. So just an added precaution.
08-20-2014, 02:17 PM
Thanks for the info on rivets ( will have to borrow air rivet gun from work to pull in a 1/4 inch rivet) I will replace the screws that dealer didn't. Cheers
2014 Forester 3051s
2012 Sonic toad
