Old 03-22-2016, 08:11 PM   #1
Gen-Turi on Forester
Anyone sing a Gen-Turi on a 2801 or other Forester with generator just behind. the driver door. Did you install it yourself or have the eaglet install it. How long does it take to set up and take down?
AbdRahim is online now   Reply With Quote
Old 03-23-2016, 12:22 AM   #2
bob dirt's Avatar
my friend has one on his diesel generator on his class A. He has it set up before you can open a beer.
2016 Forester 2401WS MBS
Life is short...eat the cookie
bob dirt is offline   Reply With Quote
Old 03-23-2016, 06:55 PM   #3
RedLdr1's Avatar
Once you install the adapter on the generator exhaust pipe putting the "smoke stack" on is very quick and easy. On my MBS I can attach the stabilizer cords to the rear ladder.
When our GTS 2800 arrives the genset moves up behind the drivers door so I picked up a set of Gen-Turi Generator Exhaust Anchors at Camping World. Those should hold it with no issues....
Wayne and Christine
2019 Sunseeker 2500TSF Pending Delivery...
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is offline   Reply With Quote
Old 03-23-2016, 08:58 PM   #4
sgtlm17's Avatar
I get this moves the exhaust above the roof but does it help at all with the sound. I've heard 1db which seems to me it doesnt
2016 Forester GTS 2801QSF
sgtlm17 is offline   Reply With Quote
Old 03-24-2016, 08:52 AM   #5
RedLdr1's Avatar
It's not a muffler... On my "W" the diesel genset is located under the bed and it makes no difference in sound level. Getting the exhaust up in the air above the roof helps disperse it so you don't get ground level "smog" cloud around your rig.
You do need to make sure your roof vent doesn't suck the fumes in to the rig. On the "W" I set my rear Fan-Tastic fan for "exhaust" and the front Fan-Tastic for "intake" to avoid any issues. On the GTS you should probably reverse those fan settings since the genset is up front.
Wayne and Christine
Old 03-25-2016, 04:06 PM   #6
My concern was how and where people attached the anchors in front of the slide. are the anchors rigid , or do they pull the pie against the coach body for support. I imagine one has to drill into the body to attach the anchors?
Old 03-25-2016, 06:11 PM   #7
RedLdr1's Avatar
The Gen-Turi Generator Exhaust Anchors are suction cups. There is no drilling required. The cords that the Gen-Turi "smokestack" uses are only there to stabilize it, they aren't load bearing....
Wayne and Christine
Old 03-25-2016, 06:22 PM   #8
Old 03-28-2016, 06:43 AM   #9
Rockin M's Avatar
A couple of years ago, while attending a RV Maintenance Rally, a Technician from the local Cummins/Onan dealer in Elkhart, Indiana cautioned us against using a Gen-Turi. Especially in close parking rallies and campgrounds or boondocking as you may blow exhaust into an open window of a neighbor RV and also as mentioned previously an exhaust fan on your unit sucking the exhaust into your rig. His advice was to let the generator blow just as its plumbed from the factory.
Barry & Donna
2014 Forester 3011DS
2013 Chevy Equinox
Rockin M is offline   Reply With Quote
Old 03-28-2016, 09:53 PM   #10
In a truck stop all of the diesel cars (big trucks) are exhausted above the roof. With the driver side slide open it has come inside the living area as plumbed from factory. I was on a coward incline on my driveway. So I guess trial and error, common sense and depends on where you are.
forester
