Old 08-19-2013, 11:35 PM   #1
Generac 40QP question
Hi all,
Just finished our first trip in our (new to us) 2011 2301. One thing we ran into was that a couple of times when we ran the generator- Generac 40QP, when we would turn the AC on, after a few minutes, the generator would sputter, stumble and then die. This seemed to correspond to the compressor kicking on.
This happened a couple of times, both while parked and while on the move. The generator has 33 hours on it and I did change the oil before our trip. This only occurred when attempting to use the AC, and not while using any other appliance.
Other than a couple of times where this happened, the generator and the AC unit functioned without issue.
Does anyone have any ideas on why this is happening, and what I should check to troubleshoot this issue? For what it's worth, the RV was originally from Indiana (closer to sea level) and we are currently in Denver, and was at a similar altitude (Mt. Rushmore) when we noticed this problem.
Any help would be appreciated! Thanks again!
specialk is offline   Reply With Quote
Old 08-20-2013, 08:32 PM   #2
GM
bclemens's Avatar
There is an altitude adjustment on the Onan...not sure about the Generac and we don't use them at the factory anymore so I can't look. I would check the manual (or search for the online manual) Should explain it there.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
