Old 02-23-2019, 02:50 PM   #1
Usually Confused Member
emm-dee's Avatar
Generator Auto-Start ???
Boondocking at a Nascar track this week. I havenít been using the generators much because the only time I need AC is for the microwave or the battery charger. Even overnight with normal TV, lights, etc. only bring the batteries down to 11.8 volts.
But today after being on battery for about three hours, and 30 minutes after a battery check showed 12.0 volts the generator just decided to start up and run. The control panel was turned off and I was the only one in the MH. Iím pretty sure I donít have an auto start option.
Anyone have this happen?
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 02-23-2019, 03:27 PM   #2
sgtlm17's Avatar
I have a 2016 Forester and it definitely does not have a Generator autostart. I checked and FR does not list Generator Auto Start as an option to your rig. Is it possible one was installed as a dealer option?
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 02-23-2019, 03:46 PM   #3
emm-dee's Avatar
I doubt it. The gen just did it again, ran about 30 minutes then shut down.
Old 02-23-2019, 04:51 PM   #4
emm-dee's Avatar
Well, just forget I asked. Did a lot of fooling around and found a “settings” selection on the app. Selected that and sho nuff there is a setting for auto start. Works great.
Old 02-23-2019, 04:52 PM   #5
emm-dee's Avatar
Hereís the display in case yíall want to check your unit.
Old 02-23-2019, 05:15 PM   #6
What year and model unit do you have , please.
Thank You; Brian French
Brianfrench65 is offline   Reply With Quote
Old 02-23-2019, 05:22 PM   #7
emm-dee's Avatar
Forester, 2018, 3051S
Old 02-23-2019, 05:55 PM   #8
HONDAMAN174's Avatar
Is it possible for the voltage amount to be changed? 11.5v is awfully low- 20% I believe.
Just glad to get away
Old 02-23-2019, 06:04 PM   #9
Witch Doctor's Avatar
That is a nice feature, like that and also the first time I have seen it.
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-23-2019, 06:29 PM   #10
emm-dee's Avatar
Yes. 10.5v to 12v in half volt intervals.
generator
