Old 12-14-2015, 04:55 PM   #11
Sagecoachdriver's Avatar
Originally Posted by MMulcahy View Post
Sage, thanks for verifying i'm not crazy.
I'm not getting how the exhaust pipe swings away. Are you saying that the bracket where the exhaust pipe terminates near the driver door, has enough wiggle room in it to allow movement of the pipe if the engine-side bracket is released, or that the pipe comes free from the engine? Or something else?
I appreciate the help.
I haven't tried it as mine only has a few hours on it and doesn't need an oil change just yet. I would remove the support bracket screws by the exhaust pipe end. Next just loosen the "U" bolt nuts just enough to twist the pipe a few inches out of the way.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 12-14-2015, 05:00 PM   #12
No idea why they would make this change.
2016 Forester 3051SF
MMulcahy is offline   Reply With Quote
Old 12-14-2015, 05:02 PM   #13
Sage, that sounds like a plan. I was tempted to do that while i was under there earlier today, but I don't like experimenting by taking things apart.
Old 12-14-2015, 05:04 PM   #14
From what I can tell, the exhaust pipe has been placed so it is closest to the front. I would assume that the pipe could have be swiveled around to another spot if properly bent.
Old 12-14-2015, 05:07 PM   #15
KJcachers's Avatar
Did they change it so it doesn't exhaust directly below a slide?
Jason and Karen
2015 Forester 3051S
2016 Ford Fiesta-Toad
https://www.visitedstatesmap.com/image/NCTNVAsm.jpg
KJcachers is offline   Reply With Quote
Old 12-14-2015, 05:11 PM   #16
A32Deuce's Avatar
Here is an idea. Under where you check/put in oil. There is a plug. You could use a step drill and make a hole opposite the plug and put a fitting with a check valve and short extension to out side pan and drain the oil.
A32Deuce is offline   Reply With Quote
Old 12-14-2015, 05:39 PM   #17
Excellent point!
Old 12-14-2015, 11:48 PM   #18
Creativepart's Avatar
How about one of those 12-volt oil changers that sucks out the oil from the fill hole. I have one I used to use with my sailboat's diesel inboard motor.
Here's a manual one that looks promising from Nothern Tool:
http://www.northerntool.com/shop/too..._390306_390306
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 12-15-2015, 05:14 PM   #19
jkoenig24
On my Dynamax Super C, they mounted the generator in such a way that it MUST be unbolted and shifted to gain access to the drain plug and filter. What should be a 10-minute job now takes an hour or more. Grrrrrrrrrr.
jkoenig24 is offline   Reply With Quote
generator
