Old 12-14-2015, 04:59 PM   #1
Generator oil change - exhaust pipe is in the way
After reviewing the owner's manual and various youtube videos, I went to the change the oil in my generator.
The exhaust pipe for my generator travels directly below the oil drain plug making a straight-on socket fit impossible. I have seen nothing about moving the exhaust pipe (how can that make sense?) but not sure how i change the oil without doing so.
Anyone else have this configuration?
Thanks for your response.
2016 Forester 3051SF
MMulcahy is offline   Reply With Quote
Old 12-14-2015, 05:02 PM   #2
Who Dares, Wins
doc73's Avatar
can't get a wrench on it? I do not know the setup.. Is there another drain somewhere? The other might be in a better spot.
What I've done with those stupid set up is added an extension tube with a shut off mounted somewhere else to save the future headache!
EDIT: what is the make and model of the geni so I can take a look at it.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 12-14-2015, 05:14 PM   #3
Generator is a Onan 4kW, model KY
thanks
Old 12-14-2015, 05:18 PM   #4
Who Dares, Wins
doc73's Avatar
Is this how yours looks?
This one has an access door on the bottom to drain through. Trying to find a picture of what you have to look at it.
2015 ChevyHD D-Max
Old 12-14-2015, 05:20 PM   #5
that's it
Drain plug on bottom behind two screw cover
Old 12-14-2015, 05:29 PM   #6
Sagecoachdriver's Avatar
I just looked at my new Forester 2701DS and the exhaust pipe is obstructing the oil drain plate and plug. Simple fix is to loosen the "U" bolts holding the exhaust pipe from the engine and remove the support bracket screws. Then just twist the pipe out of the way.
ID:	96198   Click image for larger version
ID:	96199   Click image for larger version
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
Sagecoachdriver is offline   Reply With Quote
Old 12-14-2015, 05:29 PM   #7
Who Dares, Wins
doc73's Avatar
Yes, you'll need to remove the screw. They are a torx bit. T-30 I believe. Then the oil drain is under that and will drain to the ground.
2015 ChevyHD D-Max
Old 12-14-2015, 05:30 PM   #8
Who Dares, Wins
doc73's Avatar
Ok, from the pictures above, I see now.
2015 ChevyHD D-Max
Old 12-14-2015, 05:49 PM   #9
Sage, thanks for verifying i'm not crazy.
I'm not getting how the exhaust pipe swings away. Are you saying that the bracket where the exhaust pipe terminates near the driver door, has enough wiggle room in it to allow movement of the pipe if the engine-side bracket is released, or that the pipe comes free from the engine? Or something else?
I appreciate the help.
Old 12-14-2015, 05:54 PM   #10
MMulcahy I had a look at my 2014 3051s and the pipe's not even near the drain , what did they do in 2016 thats different? (I have the same genny as you also)
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
generator
