Old 08-08-2016, 03:59 PM   #11
3M make an excellent spray adhesive that will last a long long time
Rangerdrvr59 is offline   Reply With Quote
Old 08-08-2016, 04:16 PM   #12
On my 2011 Georgetown 337DS I had a roof leak that the dealer took forever to fix. Shortly after I got it back the ceiling started to fall. I took the trim piece off, re stapled the lock piece up. Then cleaned the fabric and ceiling as best I could. Used spray contact cement,being real careful not to get any on the exterior. Then grabbed at the open seam and used a Formica roller , working It towards the lock piece. Only been 4 months,but so far so good.
2011 Georgetown 337 2011 Chevy Impala
pakkdad is offline   Reply With Quote
Old 08-08-2016, 04:35 PM   #13
Yeah, I have no idea. Mine is a thin vinyl material with a layer of foam rubber bonded to it. I've tried to see the underlayment material, looks to me like OSB board or a similar material. I haven't wanted to peel it off yet until I can get the correct adhesive to re-install it.
I am going to try and get over to the Frog rally and hopefully get an answer there.
Good luck!
Marvlab is offline   Reply With Quote
