Old 09-13-2016, 09:32 PM   #1
Gray & black pull valves HARD to close
Hello,
We have a new Forester 2401 and the black and gray pull valves pull out OK (a little tight) but do not want to push back in all the way; it's almost "spongy" feeling. The compartment door has to be pushed in while you turn the key to get it to go far enough to actually lock.
Anyone have a similar problem, or better yet, SOLUTION?
Thanks!!!
2017 MBS 2401W
BBogey is offline   Reply With Quote
Old 09-13-2016, 09:43 PM   #2
vwexpert's Avatar
Try WD40 on the shaft.
1971 20ft fireball (too small)
1987 27ft Tioga (bad brakes / tires)
1998 36ft Discovery (rattles / air leaks)
2005 37ft Monaco Knight (lemon Lawed)
2008 40ft Monaco Diplomat (too big)
2016 Forester 3011 (ordered June 8th - Born Aug 6) IT'S HERE
vwexpert is offline   Reply With Quote
Old 09-13-2016, 09:54 PM   #3
Originally Posted by BBogey View Post
Hello,
Thanks!!!
if there isn't something in the way of the gates, then lube may be all you need,....
gordonsick started the thread below about an idea he came up with to lube those, very easy mod and very helpful,....... its short, so read it all, very good info about what to use for lube and what not to use,.....
Drain valve lubrication with Silicone spray
fella10 is offline   Reply With Quote
Old 09-13-2016, 09:56 PM   #4
The handles are pushing in a cable. The cable has to be cut to an exact length. If it is just slightly too long it will flex at the end of the stroke when the valve is closed. There is no adjustment for this other than to cut a bit more off the inner cable. I would prefer them to be too long to assure the valves are closing all the way. Very common to see this on most RVs. With regards to the latch on the door. You may carefully bend the small lever that rotates on the inside of the door and is attached to the latch. bend it slightly outward to release a slight amount of tension when it holds the door closed. Easy fix..
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 09-14-2016, 12:03 AM   #5
I read the above article and had already sprayed a bit of "tool box oil" onto the shaft of each pull. The black freed right up, but the gray is still be stubborn.
The cable sounds like it could definitely be the problem as when I push the gray in, it feels like it's hitting something soft, and more force lets it push a little, but I think I'd break it if I kept doing that?
I don't see as I have any access to any of that, but I'll look in the daylight tomorrow.
Thanks!
2017 MBS 2401W
Old 09-14-2016, 09:45 AM   #6
Chief tinkerer
Gidyupgo's Avatar
BBogey, since this is a new unit, don't rule out construction debris left in the tank.
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 09-14-2016, 09:05 PM   #7
HerveVR's Avatar
Had a similar issue on our Lexington. The grey tank is on passenger side and so is located the gate valve; a long cable is needed to operate from dumping side.
Had to remove the gate valve to clean it properly twice; it fixed the problem for a while. Recently. it reappeared; will have to change the valve and adjust the cable to proper length (shorter than the original). After analysing, will probably fix for good.
HerveVR is offline   Reply With Quote
Old 09-15-2016, 07:08 AM   #8
MilCop4523's Avatar
thetford valve lube is your answer
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 09-16-2016, 11:07 AM   #9
Which end of the cable are you cutting? This makes me fairly nervous to do, and we do have it scheduled for another issue at a local dealer, but that's not for two weeks, and we were hoping to do a short 3-day camping/fishing trip next weekend - can't drive down the road with the door flapping open... (I may try that slight bend for the locking plate - but I also have to make sure as far as we're pushing it in is actually CLOSING the gray)
Thanks.
2017 MBS 2401W
black, valve
