Old 06-23-2019, 03:14 PM   #1
Bonjoey's Avatar
Grey water pipes question
Hopefully somebody have more knowledge on Sunseekers can answer my question. It happened twice now that our kitchen sink overflowed before the shower did, I thought the sink was clogged and when try to pump it, it bubbles and slowly drained but not all.
Our previous tt overflows the tub first before other drains.
I always thought the shower/tub was the lowest point on the grey pipes, that it will overflow first before other drains? Or is this a safety feature so that the shower will not overflow when the grey tank is almost full.
2019 FR Sunseeker 2650S E450SD
Bonjoey is offline   Reply With Quote
Old 06-24-2019, 03:59 AM   #2
HepvO Trap
Your shower most likely has a HepvO “waterless trap” instead of a traditional p-trap. The HepvO trap will act as a check valve and will not allow water to flow towards the shower.
Bruce
Old 06-24-2019, 08:25 AM   #3
Bonjoey's Avatar
Bruce
Thank you. I will try next time to fill the shower when the kitchen sink started to overflow again.
The brochure says Sunseekers have waste tank capacities of 39 gallons each. Ours doesn’t feel like 39 gallons
Old 06-24-2019, 08:59 AM   #4
Shredder's Avatar
Be careful if the trap in the shower seals due to back pressure of water and you fill the shower and the waterless trap opens you might have a bigger mess on your hands then you want.
What does your gauge say when the sink backs up?
Full ?? 3/4??
Anyhow good luck i usually keep the grey open until i'm about to break camp and need the grey to flush the black away.
2013 Forest River Sunseeker 3010DS
Shredder is offline   Reply With Quote
Old 06-24-2019, 09:42 AM   #5
Bonjoey's Avatar
Full ?? 3/4??
Thank you. Good thing we didnt use plunger to pump it.
Gauge says full when it starts to overflow.
Old 06-24-2019, 10:02 AM   #6
Considering that the sink is much higher and is exerting far more pressure against the "trap", very doubtful that even a shower pan full of water will have enough pressure to open it.
Water pressure in pipes not pressurized by a pump is determined by "head" which is the height of the source. Sink is higher thus greater head pressure.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 06-25-2019, 03:02 AM   #7
Exactly.
Bruce
Old 06-25-2019, 04:56 AM   #8
sounds like gauge is working accurately for now. watch the gauge and dump more often
gbaldwin is offline   Reply With Quote
Old 06-25-2019, 06:11 AM   #9
The brochure says Sunseekers have waste tank capacities of 39 gallons each. Ours doesnít feel like 39 gallons
Youíre welcome. I think that we all feel that our gray tanks arenít as big as they really are ó itís very easy to use more water than you really need to use when cleaning dishes and brushing teeth, etc. The boondockers here have all of that worked out, though.
Your idea of running water in your shower to verify the existence of a HepvO trap is a good one.
Bruce
grey water, saunseeker, sunseeker, water
