Old 06-10-2018, 10:36 AM   #1
Bezzola's Avatar
Heat/ac
When i turn my furnace on or my a/c they both run at the same time.
Has anyone run into this before
Bezzola is offline   Reply With Quote
Old 06-10-2018, 10:45 AM   #2
Bezzola's Avatar
I should have said what kind it is
Dometic in a forester class C
Old 06-10-2018, 11:07 AM   #3
T-stat setting change to auto fan
MR.M is offline   Reply With Quote
Old 06-10-2018, 11:35 AM   #4
cavie's Avatar
Are you saying that when you start the AC that the furnace comes on also?
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 06-10-2018, 12:51 PM   #5
Bezzola's Avatar
Yes
Old 06-10-2018, 12:54 PM   #6
Bezzola's Avatar
Ok ill see if i can see that on my T stat
Old 06-10-2018, 12:58 PM   #7
2012 Solera
As I remember - Set thermostat to "Fan". Use + or - to see choices - "Hi", "Lo", and "Au" (auto), as I remember. Choose "Au". Set thermostat to heat or cool - fan will cycle on and off with the furnace or the AC.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 06-10-2018, 02:15 PM   #8
Garrette's Avatar
Does the AC and gas furnace both come on when you select Heat?
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 06-10-2018, 02:20 PM   #9
bikendan's Avatar
One of the most common problem on the Forum.
Easily fixed by setting the thermostat to AUTO.
Your thermostat manual should explain it.
Equalizer WDH
Old 06-10-2018, 02:53 PM   #10
Bezzola's Avatar
Perfect thats what what it was thank you for the help
