Old 04-27-2015, 01:49 PM   #1
Heater ?
2015 Forrester 3015 ... any way to switch heat to electric instead of propane?
kjducy is offline   Reply With Quote
Old 04-27-2015, 01:51 PM   #2
TURBS's Avatar
Nope
Propane only.
Most people by electric heaters.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-27-2015, 01:55 PM   #3
Ok that's what we thought....bummer git to pack up and go refill....thank you
Old 04-27-2015, 02:08 PM   #4
TURBS's Avatar
Sorry there wasn't a better answer you wanted to hear! Lol
TURBS
Old 04-27-2015, 02:18 PM   #5
bikendan's Avatar
Nearly all RV furnaces heat by propane only. The electronics and lighting are powered by 12v battery power.
If you have hookups, most use ceramic or oil-filled heaters to supplement the propane furnace.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-27-2015, 02:54 PM   #6
Heater ?
It depends. If your coach has the (optional) heatpump on the AC unit, then you can switch to electric heat. Most people say that the heat pump only works down to about 40 degrees. I've used mine successfully down to 30.
jrwalkerpa1 is offline   Reply With Quote
Old 04-27-2015, 02:59 PM   #7
DiverT's Avatar
wally world has electric heaters for 20 bucks, thats what we use when we are plugged in, have one for the front and one for the middle and an electric blanket for our bed.
DiverT is offline   Reply With Quote
Old 04-27-2015, 05:24 PM   #8
JimOneil43's Avatar
Look up "RV comfort Systems" online. They have a electric element system called "Cheap Heat" that installs into your propane heater.
Retired and loving it...Can't wait to get back on the road!
2017 Forester 3051S ("Farley")
Born April 18, 2016
Toad: 2014 Honda CR-V AWD
GO DUCKS !!
Jim & Diana (and 3 cats)
JimOneil43 is offline   Reply With Quote
Old 04-27-2015, 06:00 PM   #9
Witch Doctor's Avatar
As stated you can add the Cheap Heat system, all it it is is a heat strip added before your duct take off. The problem is the amps it's pull and what power you have. There is a y-tube on it. I looked at that already and to me it better to change your a/c to a hp. You can also add a heat strip to your a/c unit but you will need to add a wire and new stat. then the blower will only work with blowing over the strip. Cheap Heat is not Cheap to buy or have it installed..... The strip is easy, but you need that extra wire if you can pull it. Or if you have a 2 speed blower you can just use one speed and use that wire.....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
heater
