Old 04-29-2018, 06:16 PM   #1
J42
Help finding part numbers
I need some help finding part numbers (because I don't know the names of the parts.)
My RV is a 2015 Forester 3051S
There is a plastic part which contains a cylindrical screen in the waterline just before the water pump. (See first two pics)
The second part is behind the outside access panel for the Refrigerator (Dometic RM1350MIMBSX) It is in the lower right quadrant of the panel, and is wrapped in foil. Water is coming out. (See third pic)
I'd also like to know if it's posible to shut off the water to the ice maker, since we don't use it.
I also need a replacement o-ring for the input valve on the propane tank.
Thanks in advance for any help!
Name:	2018-04-29 18.03.46.jpg
ID:	169977   Click image for larger version
Name:	2018-04-29 18.07.52.jpg
ID:	169978   Click image for larger version
Name:	2018-04-29 18.13.02.jpg
J42 is offline   Reply With Quote
Old 04-29-2018, 06:29 PM   #2
Duckogram's Avatar
Freeze damage? The first part is the strainer. You can get that from shur-flo. The 2nd part is the solenoid for your ice maker. There is (should be) a shut off valve some where near where your ice maker gets it water supply. It may be a push valve or just a simple 1/4 turn. That will solve your ice maker issue and stop the leak. I will try to find a link for your strainer assy...
Edit: This should work; https://www.walmart.com/ip/Shurflo-S...&wl13=&veh=sem
ILB ( | )
Old 04-29-2018, 06:35 PM   #3
J42
Thanks for the fast response. Yes, this was caused by freeze damage. I forgot to run the ice machine until we got pink cubes. I don't know why the strainer broke though. This was my second time winterizing. I had no issues last year.
Any help with the propane tank input valve o-ring would also be greatly appreciated.
Old 04-29-2018, 06:36 PM   #4
Duckogram's Avatar
If you can post a pic of the valve I should be able to identify it.
ILB ( | )
Old 04-29-2018, 07:04 PM   #5
J42
Propane tank pic
The diameter of the hole is 1 3/8"
Name:	2018-04-29 18.47.24.jpg
Old 04-29-2018, 09:03 PM   #6
Duckogram's Avatar
I think this is what you need. The actual valve is called 1 3/4. The gasket just sits inside.
https://www.rvautoparts.com/Marshall...iABEgJbZPD_BwE
ILB ( | )
Old 04-29-2018, 09:19 PM   #7
ice maker shutoff valve is a push pull type (white plastic). it is located under the fridge by the bypass valves for the water heater.
2017.5 Forester 3051S
2019 Jeep Trailhawk toad
Steve-W is offline   Reply With Quote
Old 04-30-2018, 06:44 AM   #8
A32Deuce's Avatar
When you winterize, after draining your fresh water tank, run the water pump a short time and that will pump the water out of the sediment filter. Do it all the time with mine. I winterize at least 3 times during the winter.
A32Deuce is online now   Reply With Quote
Old 04-30-2018, 10:20 AM   #9
J42
Thank you, everyone
Thank you to all. Every one of these responses have been very helpful.
I've got parts ordered. This all looks pretty straightforward, but I may have more follow up questions.
Thanks again!
