07-23-2019, 02:40 PM
HELP! Mysterious Piles
We haven't been in our parked Sunseeker for about a month and when I went into it to check on it found these piles of sawdust like particles in the bathroom. Maybe a combination of sawdust, plastic and styrofoam. Absolutely no damage or holes above it. Anyone have a clue what may have caused this???
TSman
2014 Sunseeker 2500 TS Chevy
07-23-2019, 03:35 PM
Can you determine the makeup of the dust? Remove the trim around the fan vent - perhaps something is within that space. If that's the source, wear a facemask....
2016 Sunseeker 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
07-23-2019, 03:42 PM
From the looks of the sawdust pile, I think you may have some hole drilling critter in a wall that's spewing it's diggings all over the lid. The angle of the spew indicates my best guess as to where to look up and down the wall somewhere in the vicinity of the toilet paper roll.
07-23-2019, 03:49 PM
I agree my cousin had to have his tt tented because of termites. Good luck
07-23-2019, 04:25 PM
Thanks for the reply. I will try that when I get a chance .
07-23-2019, 04:31 PM
Thanks for the reply. We looked all around and could not find any holes that this could have come from. There are smaller piles on the floor and some debris on the towels and rack. I saw another post that mentioned ants. Could ants leave piles like this?
07-23-2019, 05:05 PM
In a previous "sticks and bricks" home we had an issue with carpenter ants. Their piles of sawdust looked very much like that. Had to get an exterminator to fix that problem.
Glenn and Darcy
2018 Berkshire 39A
2016 Jeep Wrangler Unlimited/Blackbear (toad)
Pacific Northwest
07-23-2019, 05:15 PM
Scoundrel
Yes carpenter ants. Fairly large, black and they work very fast.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
07-24-2019, 09:29 PM
There are also boring bees that do stuff like that, they look like smalll bumble bees.
2016 Sunseeker 2700DS
2010 Jeep Liberty Toad
07-24-2019, 09:36 PM
Plumb line from pile to “above” will pinpoint exit.
2017 Puma 297RLSS
07-25-2019, 05:18 AM
lay out some glue traps or tape with adhesive up to catch whatever is in there.
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
07-25-2019, 07:20 AM
Use your phone and take a picture of the "void" in the toilet from the opening in the back, just to make sure you don't have some sort of insects building a nest inside. By the debris pattern it (if insects) looks like they might be crawling out from under the lid. It's just a guess, but I know I would want to make sure nothing was making a home inside my toilet.
07-25-2019, 07:26 AM
You might want to remove the AC vent right above it as you said there was some foam in the mix. Then check the duct work. It could be a critter in the duct or simply the construction remnants falling down when the duct came loose from the vent. Most of these vents the center rotating section has a small pin that just pops out of a hole in the center of the frame. Use a thin blade knife or putty knife to pop out the pin in the center.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-25-2019, 07:32 AM
Im suggesting ants in the ceiling. What is directly above that main pile on the toilet seat? Ants will be dropping their cuttings out of that area.
07-25-2019, 07:36 AM
Retired Old Fart
IF it is carpenter ants, that also means there is water intrusion somewhere. They only nest in damp wood, but spread out from there. Iwannacamp's plumb bob suggestion is spot on for identifying exactly where it dropped down from.
Just the 2 of us in a...
"Currently between trailers"
Sold the 246RKS in 2023
07-25-2019, 07:55 AM
TSman, did you remove the trim around the fan opening? You won't be able to see in there, until you do that. That trim may also mask the true source of the sawdust, as the sawdust can travel down cuts in the trim and come out elsewhere.
Removing it is very easy. Just remove the 4 visible screws and pull it down. Like brucemc says, I'd wear safety goggles and a dust mask, when you do it. You are likely to get a face-full, when you pull it down. It might also be a good idea to spread newspaper, or some plastic sheets around to collect the sawdust.
Good Luck.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
07-25-2019, 09:35 AM
Carpenter bees! Very familiar with them. They look like large black bumble bees here. They normally leave perfectly circular holes when they nest and as I indicated, I cannot find any holes where this material came from.
07-25-2019, 09:44 AM
I looked inside the toilet and flushed it and did not see anything wrong. I did notice that almost all the water in the bowl was gone. When you talk about the void, do you mean where the water pipe comes out of the wall?
07-25-2019, 09:48 AM
Thank you everyone for the ideas and replies. I checked it today and have not seen any new material appear. I will take the trim off later to check it. The corner of the fan from is right above the larger pile. I will post myfinding.
TSman
07-25-2019, 11:05 AM
I just checked under the trim and found 2 tiny ants and a little debris but not nearly as much as on the floor. Again, no new debris. I think they started to build in the roof but may have gotten fried in the hot weather. Set some ant bait traps and will hope for the best.
Thanks again everyone for the help.
TSman
