Old 03-23-2014, 05:39 PM   #1
Frank & Eve's Avatar
Help please !! Electrical Outlet Still learning !!
Getting ready to leave the campsite today we discovered that while being plugged in to the 30 amp outlet for 2 nights the outlet was not working properly. Our coach batteries were drained, the generator wouldn't start. Could not get the slides in or the jacks up. Luckily we had a 110 adapter plug....so we plugged into 110 long enough to get the generator started. Were able to then get the slides in and the jacks up. My question is how do you know for sure that the 30 amp outlets are working correctly. And what would we have done if the 110 was not working ? Suppose we could have left the engine running long enough to charge the coach batteries. Are we missing something here??
Sent from my MB886 using Forest River Forums mobile app
Frank & Eve is offline   Reply With Quote
Old 03-23-2014, 05:42 PM   #2
Did you not use any 110v during the weekend?
Old 03-23-2014, 05:46 PM   #3
davel1971's Avatar
I'm still trying to figure that out myself OldCoot. Seems like you would know right away. There has to be some sort of indicator somewhere if the coach in there avatar is what they are asking about
David & Lynn
Old 03-23-2014, 05:47 PM   #4
wmtire's Avatar
I think you are trying to say the 30 amp outlet (which is a 110/120 volt) was not working and you has to use an adapter to plug into the 15-20 amp outlet (which is also 110/120 volt).
It's also possible, you are referring to the 50 amp 120/240 split phase service as the 30 amp service.
Both the 30 amp and 15-20 amp outlets are wired for 110/120 volts. Even the split phase 120/240 volt 50 amp outlet only uses each leg separately which are each 120 volt. This pic may help in which outlet you are referring to
Just about every RV only uses 120 volt, which is what confuses many people. Even when plugged into a 120/240 split phase 50 amp service, the RV is wired in such a way that it uses the TWO 120 volt legs separately, and never combines them to make 240 volts.
This article may help in the understanding of it all:
http://www.rvcruzer.com/electrical/chapter3.php
If you carry a voltmeter with you, you can easily check ALL outlets before plugging into them. You can also make a fairly cheap outlet tester for this purpose. And if you have certain surge guard/circuit monitoring systems, it can also alert you to problems with the outlet.
You can learn to use a multi-meter or make your own plug-n-play outlet tester here: Click the left hand tab on outlet testing.
RV Electric
2011 Flagstaff 831 RLBSS
I’ve lost my scapegoat.
Old 03-23-2014, 05:50 PM   #5
BamaBob's Avatar
Just curious blevinseve - what type of rig do you have?
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 03-23-2014, 05:55 PM   #6
BamaBob's Avatar
Also, this is a really good surge protector and even though it is expensive, it will not only protect your rig but let you know when things are not working so goo (or as in your case, not at all!)
This is a 50amp unit, you may need the 30 AMP unit they sell depending on your rig:
Amazon.com: Progressive Industries EMSPT50C Surge Protector: Automotive
Old 03-23-2014, 06:07 PM   #7
Commercial Member
This is what I use. It has lights that code if the campgrounud post is wired correctly or not. many are not up to code.
Google "Progressive 30 amp" You can get for less than $100 and it has saved me a couple times.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 03-23-2014, 06:07 PM   #8
After plugging into the 30 amp receptacle, I use an inexpensive circuit tester to test a 110v outlet for polarity. That tells me all is good (or not) with the shore power.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 03-23-2014, 06:34 PM   #9
Well if your microwave display is lighted, you have shore power. If it isn't, you don't.
2014 Sunseeker 2300 Chevy
Snowman9000 is offline   Reply With Quote
Old 03-23-2014, 06:36 PM   #10
My 30 amp cord has a red light on the female end that plugs into the camper that lets you know you have power.
electric, electrical
