Old 03-03-2016, 07:11 PM   #11
Air Force Retiree
Get yourself a front receiver hitch for your truck is the best solution.
Retired Air Force is offline   Reply With Quote
Old 03-03-2016, 07:15 PM   #12
vwexpert's Avatar
Stlcaly...If you look at the thread you will notice it's in the Class C Forester section and if you take a second to look at the person signature you will notice he has a Class C motorhome.
1971 20ft fireball (too small)
1987 27ft Tioga (bad brakes / tires)
1998 36ft Discovery (rattles / air leaks)
2005 37ft Monaco Knight (lemon Lawed)
2008 40ft Monaco Diplomat (too big)
2016 Forester 3011 (ordered June 8th - Born Aug 6) IT'S HERE
vwexpert is offline   Reply With Quote
Old 03-03-2016, 07:15 PM   #13
KAS
Mine has a steel tongue that goes all the way to the back. It's very sturdy. I can use it also as a platform for a lawn chair when parked (would be funny while driving ).
KAS is offline   Reply With Quote
Old 03-03-2016, 07:21 PM   #14
KAS
Originally Posted by mikejm View Post
Your carrier looks fine. I reinforced mine with a steel plate on the bottom of the carrier tongue because it does bounce a little on the road so did'nt want too chance aluminum tongue bending or breaking. Safe travels .
mikejm
see #13
Old 03-04-2016, 02:14 PM   #15
Sagecoachdriver's Avatar
Anyone use a ladder rack for bikes?
Looks like my bike will have to go on the ladder rack, has anyone had any problems with weight on the ladder? It shouldn't be more than 45 lbs total.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 2 trips 5 nights
Sagecoachdriver is offline   Reply With Quote
Old 03-04-2016, 11:07 PM   #16
May try this
HF has a smaller aluminum cargo carrier that will work if I turn the tricycle front wheel sideways and have the rear axle laying on top of the basket. I would need to buy a 4" riser to get it up as it would surely scrape going up and down driveways.
ID:	101088   Click image for larger version
Old 03-06-2016, 12:40 AM   #17
you should be able to fit the trike on a four bike rack with room for your bike as well. lifting it up onto the rack might be a problem depending on physical ability.
poorbuthappy is offline   Reply With Quote
Old 03-06-2016, 01:23 AM   #18
caper's Avatar
$179.99 at HF.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-06-2016, 01:34 AM   #19
Found this one and it would be perfect. BUT when I called manufacturer, they said NOT for RVs because overhang. It must be 72" or less otherwise there is too much stress especially on the fold-up models. I have 96" of overhang.
Perhaps I could add 2 bolt-on receivers in bottom photo on the bumper and add 2" by 2" metal tubes to the basket for more support and stability????
Caper, I saw that at HF and manual says not to exceed 55 mph with carrier attached.
ID:	101175   Click image for larger version
Old 03-31-2016, 01:25 AM   #20
Received the cargo basket today, not the one in the photo NO bike rack or folding. Ran by HF for a hitch riser. They were out of the double and had to get the one with a tongue for a ball. Looks like it will all work for the tricycle. Will have photos tomorrow. But will have to exchange the hitch riser as they welded the top receiver crooked and everything is thrown off. The receivers and 2x2's have some sway and I will need to pickup 2 hitch tighteners,
Now what to do about my bike. Has anyone used a ladder mount for their bikes on a Forester or Sunseeker? I had no trouble with my Winnebago Minnie mounting 2 bikes on it for 2 trips to Yosemite. But this is no Winnebago.
I have considered a bumper mount Bike rack which I can squeeze one bike in maybe??? I would have to modify it and remove the second bike tray.
hitch
