Old 04-05-2018, 12:52 PM   #1
LinandLen's Avatar
Hole in battery compartment.
Is the round hole in the step house battery compartment supposed to be there? I just donít remember seeing it, but Iím assuming this is for ventilation. ??
Linda and Lenny
2016 Forester 2861DS
1995 Jamboree 31N (2000)
1979 Tioga 25' bunkbed (first RV in 1992)
LinandLen is offline   Reply With Quote
Old 04-05-2018, 12:56 PM   #2
More than one hole likely. One unused, for off gassing, and one, used, to pass wires through (probably at least the ground to chassis)
2016 SS 2250 E450
Dp26 is offline   Reply With Quote
Old 04-05-2018, 01:10 PM   #3
Duckogram's Avatar
It is a vent hole. Here is what I did to address the open access issue. I did because of where I live. It may not be necessary for you.
2800 QS Mods
ILB ( | )
Old 04-05-2018, 01:21 PM   #4
LinandLen's Avatar
Thank you so much for the idea! I thought I was going crazy because I just never noticed that hole. Weíre on the road right now and will be camping at a sustainable farm. Iím sure there will be little critters involved. I just donít want any little visitors climbing through that hole into the RV. Weíre not able to fix this right at the moment, so do you think a little critter could squeeze through the step??
Linda and Lenny
Old 04-05-2018, 05:32 PM   #5
Tinkerer and Putterer
Nope. The step / cover has a gasket to make it water / gas tight. As long as the gasket is in place no squeezing should be possible unless it's a tiny tiny bug and then they'll find other ways in as well...
My problem with it was that water from the road got in.
HappyGuy is offline   Reply With Quote
Old 04-05-2018, 09:38 PM   #6
Duckogram's Avatar
What happyguy said and as long as the battery cables have the foam seal in tact then not an issue. My concern is having a cottonmouth, coral or rattler crawl in there and sayin howdee do when I open the step/cover. Already had one under the front hood. Fortunately it was a King and more scared than me.
ILB ( | )
Old 04-06-2018, 01:50 PM   #7
I put some wire mesh over the hole and secured with silicon around the edges, it can still vent. We had a mouse problem but that seems to have solved it along with filling all other gaps I found.
2015 Solera 24R
2014 Mercedes Chassis
Karter is offline   Reply With Quote
Old 04-06-2018, 02:16 PM   #8
LinandLen's Avatar
Duckogram, wow!!
Linda and Lenny
Old 04-06-2018, 03:30 PM   #9
X2 with Karter. Works on my SunSeeker.
2014 SunSeeker 3050SF
2012 Honda CR-V Toad or
2013 Honda CR-V Toad
UpstateTiger is offline   Reply With Quote
battery
