Old 05-17-2016, 04:59 PM   #11
Fundamentally the problem is that monitoring voltage is a real bad indication of battery condition. What most good monitors do (Bogart, Victron, etc) is monitor current into and out of the battery bank. That way they calculate the state of charge using discharge and charge current. First thing is if you have a converter, as soon as you connect, the system voltage will jump to the converter output, just like the LEDs in the panel do.
Conventional wisdom is that you can only even try to predict battery condition if you measure the voltage after all charge and discharge current has stopped for at least 6 to 12 hours and the battery has settled down and all surface charge has dissipated. Even then, voltage remains a very poor indicator of state of charge.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 05-17-2016, 05:02 PM   #12
BandJCarm's Avatar
OK, makes sense but I'm still trying to figure out if that Bogart unit measures one battery only? IF so, do you need two? Or what?
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 05-17-2016, 05:10 PM   #13
HopHed's Avatar
The Bogart Trimetric measures the system voltage from a shunt installed off of the negative side of the battery. It will also measure the voltage of a second battery which is usually the engine battery but will not indicate battery drain(amps/watts) or % of charge which it does for the coach batteries. Read the material on it on their web site. Great battery monitor and combined with their solar controller even better.
1978 Ford Rollalong
2004 Fleetwood Tioga 29V
2016 Forester 2861DS (11-13-15)
HopHed is offline   Reply With Quote
Old 05-17-2016, 05:15 PM   #14
Bogart will actually monitor two, but only measures current in and out of one of them. That is because when you have a bigger house bank it is usually connected as a single bank of either 12 volt units in parallel or 6 volt units in series and parallel. My RV has 4 12 batteries in parallel and they are treated (charged and discharged) as a single bank. The second Bogart monitor connection is for the chassis battery in an RV and they only display voltage from that unit.
When managed correctly, a bank of multiple batteries can be treated as a single large battery. Sure you might get a bad cell eventually, but that will be long after the bank is ready for replacement. Since Bogart and Victron systems act like bank clerks and only measure discharge (withdrawals) and charge (deposits) it is a good idea to take a look at all batteries and cells every few months with a real hydrometer. This will confirm that all cells are good and that you don't need to equalize your batteries with a 4 hour charge cycle of maybe 15 volts. Few people actually equalize, although Bogart has a companion solar charge controller that has an equalization option and it communicates with the battery monitor for a display and current measurements.
2015 335DS
Old 05-25-2016, 09:11 PM   #15
Monitor Panel LIght
Is there anyway of resetting the monitor panel lights for water. All mine are reading wrong. Even the storage tank and we are on city water. I have tried turning off electricity and battery power thinking it would reset. It didn't work. I know it's empty. We dumped and rechecked, still reading wrong. Any suggestion or is it in need of shop repair?
Randy Ashley is offline   Reply With Quote
Old 05-26-2016, 12:31 AM   #16
Creativepart's Avatar
You are thinking that the monitors are more high tech than they are. There is nothing to calibrate or reset. It is physical water sensitive circuits mounted in holes in the tanks in thirds up the side of the tank. When the fluid level rises it closes a circuit and that activates the light.
TheY do become clogged, broken and unreliable - but there is no logic board to reset.
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 05-26-2016, 07:05 AM   #17
That's good to know. We have been on the road a couple weeks. This makes sense. Thanks again. Shirley
battery
