Old 09-10-2015, 10:57 PM   #51
Creativepart's Avatar
It's not the SD card. It a microSD card and if you have NAV then you have one. Look to the right of the disk slot. There's a small flush door there. It opens from the left and is hinged on the right. Once open you'll see a small slit. Push it, it's spring loaded and the microSD will be removable. That's what you'll need to access on your PC with the toolbox program you need to download and install.
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 09-11-2015, 07:23 PM   #52
papap's Avatar
I download the app. Then put my card in a card reader. Can not get app to work with card. Going to try again tonight.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 09-27-2015, 08:23 AM   #53
Sundown's Avatar
Problem with jensen vm9726bt gps shutting off
I have Jensen vm9726bt GPS in 2015 Forest River Sunseeker that shuts off after traveling for an hour or so. It shuts radio off too. I can get the radio to come back on by shutting it off and turning it back on, but the GPS will not come back on. After stopping for the night it will work again for awhile the next day but shuts off again. Also speed limit info gets stuck on 50 miles per hour. Has anyone else had this problem and is there a fix.
Sundown is offline   Reply With Quote
Old 10-03-2015, 03:00 PM   #54
Karen, Pete & Chloe Kat
sanpedroflyer's Avatar
Jensen GPS Files and Navie Tools on PC
Hi,
I took delivery of a 2015 Solera 24R in early July. The Navie Tools said my first GPS fix was early June.
I am a Mac Person, but have some PC experience. Here's what I have found so far:
There is a folder on the Micro SD card (attached MicroSD/SD to the PC like a Flash Drive and double clicked on the Micro/SD card. That brings up a new screen with folders.
I am trying to figure out how to copy or print the file directories, but for now I am in a directory called:
Remove able Disk (E)/RTNavi/content/map
It contains a Basemap file, a Canada file, 3 North America files and 50 + state map files.
The "Basemap.Fbl file is dated 10/2/2015 7:09 PM and is 8,690 KB
All other files are dated 12/28/2013 10:18 AM and range in size from 355 KB for USA Virgin Islands to 105,035 KB for USA_Texas.
Before I got to this point, I sent an email to Naviextras support and received a reply from Nicole:
Dear Peter,
First of all, thank you for your interest in our products!
My name is Nicole and I will handle your issue from now on. Please excuse me for the delayed response.
I understand that you cannot connect your device to Toolbox.
To be able to investigate this issue, please attach the content of the license folder of the SD card or the internal memory of your device (in case of some head units, on the USB stick) in compressed format (.zip or .rar).
For this, please attach your device to the PC. If you are connecting your device via USB cable, turn it on. Now go to Computer using Windows, find your device as a removable drive or disk. Double click on the drive, and find LICENSE folder. Now right-click on LICENSE folder, and choose "Send To - Compressed (zipped) Folder". Now your computer will make a compressed file called "License.zip". Please attach this License.zip to your email reply and send it to us.
Thank you for your cooperation.
Best regards,
Nicole
Naviextras® Support
I hope to post more details of the contents of the Micro SD card which contains the iGo Primo application and a bunch of others including the map files.
One more point. If you go to eBay and search on iGo Primo and Map or GPS map you should find CHEAP maps. I DO NOT KNOW if these are compatible with the Jensen iGo Primo software or not.
MicroSD card iGO Primo Nav Software 2015 / Android GPS + USA CAN+MEX map
2015 software with 2014 Q2 North America map
$31.99
Buy It Now
Free shipping
When I sent a question to one of the vendors asking if his maps were compatible with Jensen GPS, he responded:
"Dear sanpedroflyer,
Hello dear does it have WinCe operating system?
or it is Android?
- moti_eval
Hopefully I can post more info
sanpedroflyer
sanpedroflyer is offline   Reply With Quote
Old 10-03-2015, 09:58 PM   #55
I'm a Mac user, but run Parallels Destop to run Win 8.1 and so I can run the Naviextras program. From what I can tell (from my experience) you cannot backup or update your MicroSD card for use in your jensen GPS without using a Windows operating system and the Naviextras software.
Their software reads not only the license but the device ID from the files on the card. It works like DRM to prohibit files from being copied and sold or shared.
Old 10-03-2015, 11:20 PM   #56
Sagecoachdriver's Avatar
Creative part, did you buy the update? I have been able to copy my microSD from the 4GB to a 16GB and it works fine in the Jensen. I think
FR and Jensen should do something about these 3 year old maps many of us are stuck with.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 10-04-2015, 11:38 PM   #57
I did purchase the upgrade. We're in the last week of of a 3,500 mile trip and I wanted accurate maps. I did the upgrade before we left at the beginning of Sept. No idea how much difference it made, if any.
The GPS isn't RV savvy, but it has proven accurate enough.
Old 10-05-2015, 12:00 AM   #58
Creative part, do you know the date of your maps?
Old 10-05-2015, 09:43 AM   #59
Boso's Avatar
Creativepart what makes it not RV savy and is it set on bus so far I don't see any difference in the Jensen,Garmin, or the pioneer and I know mine doesn't have the latest update yet
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 10-05-2015, 10:08 AM   #60
I'm not where I can see the map dates. My memory is that they were from April, 2015 but don't trust my memory.
There are a couple of "RV GPS" systems out there that have the GoodSam or other RV Park lists in their database. This system has all the KOAs in their database, but we find about 60% of the private CGs we visit are not listed in their system. So, we have to enter addresses to the Park. We are in such a park today in Destin, Florida. The GPS not only didn't list the RV Park, it didn't even have the physical address in it's database. We set it for an address close to the RV Park that was in the system (something like a "house" number of 50 rather than the real number of 1047) to get us within range and then relied on our phones for the final few miles.
Also, the RV GPS systems (from Rand McNally and Good Sam, etc) have road settings for Motorhomes. The iGo system has road settings for Car, Truck and Bus. I'm using the car setting because the Truck setting effected the route more than I liked.
jensen
