Old 03-26-2012, 02:31 PM   #11
I sure hope it's not under the bed. I drain and fill our tank with fresh water before every outing, which is every two weeks from April to November and at least once a month during the winter. I'm really gonna hate it if I have to take the bed apart every two weeks.
Blessed are the cracked, for it is they who let in the light
modmidget is offline   Reply With Quote
Old 03-26-2012, 10:31 PM   #12
GM
bclemens's Avatar
The bed lid should be hinged. Lift the mattress...the top of the bed base should lift up...or there is one screw.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 03-27-2012, 12:24 PM   #13
There are no hinges and the plywood is held down by 6 screws.
Old 03-27-2012, 12:40 PM   #14
2012 Flagstaff 25KS
Just bought our trailer last month. During the PDI I asked the tech how I would get the slide in if the electric feature failed. He didn't know. He took off several panels but could not find anything. The manual shows a drill or electric screwdriver inserted into the end of a motor, but where is the motor??
roanmountaincampers is offline   Reply With Quote
Old 03-27-2012, 12:42 PM   #15
Tech was able to show me the fresh water drain which is up under the trailer near the axles. Have to take a cap off the outlet to let it drain. Only way to get to it is to get down on your back and slide under. Seems like there could have been a better way.
Old 03-27-2012, 08:21 PM   #16
GM
bclemens's Avatar
well, hmmm. I guess that is something they have switched out there. I haven't seen a 2650 run in a while. I'll have to go see if we have one online.
Old 04-02-2012, 02:36 PM   #17
I was able to drain the fresh water tank by removing the cap from the cold water plumbing drain located behind the right rear mud flap and then running the water pump until it pumped all the water out. Will I damage the water pump by running it like that for an extended period? I don't want to burn the pump out.
Old 04-02-2012, 02:39 PM   #18
TURBS's Avatar
hey what do you know another dealer FAIL !
According to your list those items should have been discussed !
Old 04-02-2012, 03:02 PM   #19
Herk7769's Avatar
Going through this in another thread.
If your slide was made by Lippert, there should be a stub shaft with a large roll pin in it. It may be on the side opposite the slide.
Name:	9 Nov 2009 002.jpg
ID:	11624   Click image for larger version
Name:	9 Nov 2009 003.jpg
HAM CALLSIGN - KC3FFW
Old 04-03-2012, 09:06 AM   #20
GM
bclemens's Avatar
That is not the same slide. Lippert makes multiple styles of the slides. The 2651 will have a shaft with a cotter pin in the roof of the storage box below the slide.
