03-20-2017, 08:47 AM
#21
I am sure they probably worked very well,,, until they got painted !!!
03-20-2017, 09:54 PM
#22
Yup one of tabs won't lock I attribute it to paint.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
03-24-2017, 05:42 PM
#23
Thumbs up, press up and out, harder, harder, come on, put the thumbs into it. It will open and actually gets a touch easier. Either your thumbs will strengthen or the tabs will loosen.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
09-27-2021, 06:22 PM
#24
I have a 2021 Rockwood 2608BS and am not able to close my vent, it is off centered by about 1/4”. My wife says to take it back while it is under warranty, but I kind of like the idea of using a knife and cutting the sides of the tabs down.
09-27-2021, 06:32 PM
#25
Georgia Rally Coordinator
No big deal to just leave it open I do mine that way no issues. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
10-01-2021, 09:16 AM
#26
X2. I’ve left the flapper unhooked on every rig I’ve owned. Never a problem…nothing enters and none have ever fallen off.
BIRDS AREN’T REAL
10-02-2021, 07:15 AM
#27
It is a big deal if we leave our range vent flap open during travel. Since the thread is about a motorhome, it should be noted that, depending on the model, it can be very noisy traveling with the flap open. Your signature says you have a fifth wheel, if I researched it correctly, so you and others with trailers probably wouldn’t notice the vent noise when under way.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
10-02-2021, 08:48 AM
#28
Notices to Stink Bugs, Come on in !!!
LOL !!!
10-02-2021, 09:37 AM
#29
I have the 3051 motor home and never hear any noise from the flapper. Been a long time but I don’t remember the 1979 Winnebago mh having vent noise.
BIRDS AREN’T REAL
10-02-2021, 01:46 PM
#30
Right. That’s why I said, “depending on the model.” Ours was horribly noisy on the first day drive home from the dealer. We quickly figured out that the range vent flap being open was the cause. Its good that yours is quiet.
10-02-2021, 07:18 PM
#31
Interesting. Your MH has the flap on the pax side, along with a lot of other stuff which definitely would create turbulence leading over the flapper (heater and refrigerator vents, door, door grab handle). The 3051 has the flapper on the driver side with only two fairly flush mounted windows forward of the flapper.
Could very well be the difference in noise levels inside.
BIRDS AREN’T REAL
10-02-2021, 07:59 PM
#32
You’re probably quite right. The air flow is surely “dirtier” on the curb side, what with the awning rails and the coach door, grab handle, etc that you described. I hadn’t thought of that as a contributing factor in range hood vent noise during travel.
