Old 01-30-2017, 07:13 PM   #1
How to open the stove vent
My Forester has a plastic stove vent with a covered flapper. The flapper has tabs on the bottom edge that apparently lock the flap. How do you unlock the flap, I've tried pushing and pulling the tabs, but they don't seem to move.
Dave W AKA "Toyman"
Well modified Forester C 2551
Why ?...Why not ?
Toyman is offline   Reply With Quote
Old 01-30-2017, 07:20 PM   #2
Wobbles's Avatar
Do the tabs have a screw? While I have a TT, I have the tabs and have to rotate them out of the way.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 01-30-2017, 07:27 PM   #3
fonzie's Avatar
Stove vent
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 01-30-2017, 07:43 PM   #4
Flybob's Avatar
On many, the little tab rotates around the smaller end to allow the flap to open. When new they can sometimes turn hard. Be sure to close it and lock it prior to traveling as they will flap and fall off.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-30-2017, 07:52 PM   #5
If they are plastic tabs molded into the bottom of the cover flap, push harder and in an upward direction. They can be very stiff when new.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 01-30-2017, 08:12 PM   #6
SailorSam20500's Avatar
This was showed to me during my PDI, guy said just give it a push and it'll pop open. NOT!!! So he tried and gradually increased the pressure. Then he slid a mini screwdriver along the bottom. Factory got some sealant on the bottom edge and glued it shut. The screwdriver broke the sealant, works fine now... Still is a bit stiff, DW wouldn't be able to open it, but then again, she'd need a stool just to reach it!
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 01-30-2017, 08:16 PM   #7
RSchleder's Avatar
X2 --Use both your thumbs on one tab at a time. Push the tab up and slightly out from the trailer. After the 1st tap releases, go to the 2nd tab and perform the same process. This will now allow the vent to "open" when the vent fan is turned on and the vent will exhaust the fumes.
To close, simply reverse the process, again, 1 tab at a time. I also agree that these tabs are very stiff when new, however, they will "loosen up" as they are used. You'll probably want to snap the vent close when finished cooking as the vent will flap with even minimal wind/breeze and drive you nuts!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 01-31-2017, 02:07 PM   #8
Mtnman64's Avatar
Stove vent
That is a perfect technique, as I employed it for the first time today !!
Mtnman64 is offline   Reply With Quote
Old 01-31-2017, 06:08 PM   #9
stove vent
If the flap moves at all it's likely the tab issue but if it doesn't move it was likely sealed shut at the factory by some careless workman. Mine had to be pried open with a putty knife. Works fine now. Happy camping.
DocRob is offline   Reply With Quote
Old 01-31-2017, 09:53 PM   #10
Thanks for the responses....it WILL be opened!
Dave W AKA "Toyman"
Why ?...Why not ?
vent
