08-04-2017, 04:44 PM
How to remove drawers
I need to get the drawers out of the slides to follow some cable and I can't figure out how to get them out. They aren't exactly like mine at home and I'm scared to pull or tug real hard. Any words of advice? This is what the drawer slides look like.
2022 Rockwood Signature Ultralite 8262rbs
2022 Ford F-250
08-04-2017, 04:55 PM
I'm not certain but don't you push on that black oval shaped "button", on both sides, to release the forward rail from the track?
2012 Sunseeker 2250S/2008 Yamaha Venture (1300 cc V-Four)
08-04-2017, 04:57 PM
Canadian Member
Pull up or push down on the black plastic pieces extending beyond the outer glide.
Originally Posted by Melntb1
I need to get the drawers out of the slides to follow some cable and I can't figure out how to get them out. They aren't exactly like mine at home and I'm scared to pull or tug real hard. Any words of advice? This is what the drawer slides look like. Attachment 147173Attachment 147177
My drawer slides look the same as yours. The little black tab on the side, which I can see in the picture, has to be pushed up while you pull or pushed down. One side of mine had to be lifted while the other had to be pushed down. Good luck.
2016 Forest River Wildcat 314BHX
2019 Ford F-450 Limited DRW 6.7 Diesel
08-04-2017, 05:02 PM
Had mine out the other day. The black skinny plastic skinny fingers need to be raised up with door pulled out and you can then pull the drawer out. I found it best to when want to put the drawer in to have the slices fully in them slide drawer back in the slide rails . Hope this helps
08-04-2017, 05:13 PM
Same with my drawers, the pointy tab needs to be moved up or down and each side is moved in the opposite direction. Move the tab in the direction with the most travel distance, the one in your picture would be moved up. I find it helpful to push the drawer back in a bit after holding the tabs in position and then pull back out.
2017 Forester 2861DS
towing 2015 Jeep Rubicon
08-04-2017, 09:07 PM
Thanks everyone! As usual y'all never steer me wrong
2022 Ford F-250
08-05-2017, 07:37 PM
easy to do
These drawers have that little tab or lever on the sides that you have to lift one side and depress the other to get them to release. Left up, right down or vice versa. It's easy once you get the hang of it.
08-05-2017, 08:47 PM
It's Much easier to remove you pants First!!!! LOL!!!!!
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
08-05-2017, 09:09 PM
[emoji23]
2022 Ford F-250
08-05-2017, 09:50 PM
Our cats like to get into and behind those drawers - a real PITA to get them out.
2018 Flagstaff 29KSWS
2008 Ram Laramie 3500 Megacab 4x4 Cummins 6.7L Turbo Diesel
08-06-2017, 07:17 PM
there should be ears on each side left one another down then pull it out
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
08-13-2017, 08:49 PM
Chief tinkerer
because it is the same slide PN.... flopped over to fit left or right side... to release, one side down, other side up. (I had to ask too, first time)
Gary
2017 SunSeeker 3010DS
