Okay, I've learned a lot in the last two days. I have a new Forester 3011DS. I'm in Houston and it rarely gets too far below freezing down here.....but it did a few weeks ago. My unit has a button on the touch panel (One Control) even though my FR MSRP build sheet says I don't have the arctic package. Given that, I had the MH in the driveway and ran the heat inside during the cold weather. All seemed good until last night when I turned on the water pump and water came out the refrigerator cover outside.
The ice-maker valve had cracked. I did not have the arctic button on during the freeze as I didn't have much in the holding tanks and the fresh water in inside under the bed is almost full. That would take some really cold weather to freeze. That being said, I found a heater wrap around the ice-maker valve. Is that 12v or 110v?
I also learned the ice-maker valve is 110v only, so no making ice while traveling or not on shore power (or generator). Good to know....
I found an exact replacement valve on Amazon for $28. Lesson learned...easy to replace as it took me 2 minutes to take the cracked one out. I turned off the supply to the ice-make with the push/pull valve under the oven. No other damage due to freezing as water work fine.
I want to test the heating wire that wraps the valve but I think it has a thermostat and needs to be below a certain temp to come on. Since the valve is so close to the outside, I fully understand why it froze and cracked.
Any info is appreciated. I've only had this thing for 2 months now and I learn something every time I use it.
Thanks in advance.....
