Old 08-14-2018, 05:27 PM   #1
Improving Forester Driveability
I bought a 2005 Forester 2 years ago and have put about 5000 miles on it so far. I have installed Road-master anti-sway bars on the front and rear and will do a steering stabilizer this Fall. I'm wondering what others have done to improve your ride and handling. I've had a few people recommend Sumo Springs, so I'm just looking for what others have done to improve the ride and handling of your Class C models.
toddlafond is offline   Reply With Quote
Old 08-14-2018, 06:17 PM   #2
No-Fish's Avatar
I didn't see which model you have, Ive got a 2016 3011. I replaced the front and rear sway bars to Hellwig"s, installed Monroe coil over rear shocks, and a S/S rear trac bar. also had the front end align'ed.Still need to install the front shocks. I replaced the OEM steering damper, w/ a bilstein. I handles like my f350 dually.
Happy Travels
No-Fish is offline   Reply With Quote
Old 08-14-2018, 06:54 PM   #3
Ford or Chevy?
Dave W AKA "Toyman"
Well modified Forester C 2551
Why ?...Why not ?
Toyman is offline   Reply With Quote
Old 08-14-2018, 07:13 PM   #4
Ours drives great right from the dealership . E450 ,2017 3010ds . I drive a E250 for my work van , no mods needed.
fred+sherry is offline   Reply With Quote
Old 08-15-2018, 03:13 AM   #5
kijak's Avatar
I have a 2018 Forester 3011, and experience a bit of drift, even in low wind, I think a lot of busyness on the stearing wheel, to just keep is between the lines, run 70 lbs in the rear airbags, but that is usually down to 45 in a few days. I have a apt with Ford dealer to take a look at it all, and advise for a better driving experience. I have driven 3 different class C's in renting and this is what I have experienced.
Jack & Kim Blaydes
2018 Forester 3011DS
2011 Rockwood 8285WS (The Mobile Cabin) traded
2004 F350 SuperCab 6.0TD DRW (Mr. Duals) sold
kijak is offline   Reply With Quote
Old 08-15-2018, 09:04 AM   #6
I'm sorry I should have included that it is the 2861 built on a Ford E450.
Old 08-15-2018, 09:19 AM   #7
Steeljag's Avatar
X2 !
So far, so good with no after market products ! Just over 5000 miles, still handles just fine, and I can drink my coffee while cruising down the roadways!
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 08-15-2018, 09:40 AM   #8
I added Hellwig antisway bars front and rear, Roadmaster steering stabilizer, and verified the positive caster with an alignment at a truck shop.
On our last long trip, I noticed that reducing weight in the far rear storage made a huge difference on the need to saw the wheel back and forth constantly. I try to keep as little as possible back there and have only a tiny amount of water onboard while traveling.
DW, DD (sometimes), DS (sometimes), 2 camping poodles
2017 Forester 3011DS
mbutts is offline   Reply With Quote
Old 08-15-2018, 10:10 AM   #9
I replaced both front and rear sway bars w/ Hellwigs. I then took the rig to a Truck and Spring shop and had them pull off the air bags (hate them) and add 2 additional leaf springs on each side of the coach. I then had them align the coach.
I ended up with +7 caster on both front wheels (the side that is supposed to have more does have a little more - I can't remember the exact numbers). A little over Ford spec, but I was advised the extra caster would do nothing to the steering component or tire wear.
I can steer my rig now w/ 1 finger doing 70. Before people get excited, I normally drive 62-65, but I just wanted to see.
2020 Rockwood Mini Lite 2509s
2019 F-150 3.5 EB SCREW Max Tow - 1797 payload
Blue Ox SwayPro w/ 1000 lb bars
s1njin is offline   Reply With Quote
Old 08-15-2018, 10:49 AM   #10
Empty Nesters
KenandCarol's Avatar
Originally Posted by Steeljag View Post
X2 !
X3.
I have a 2017 2250 Sunseeker on an E450 chassis. One thing that helped me was the advice on here to "load her up". The E450 is really overkill for this thing but they stopped building them on the E350. I have a CCC of over 4200 lbs! Putting in a full load in the FW tank cured all my handling issues. Everything stock.
2017 Sunseeker 2250 24' MH
KenandCarol is offline   Reply With Quote
Old 08-15-2018, 01:02 PM   #11
My 2012 3011 drives wonderfully with just the factory components. Your problem may simply be oversteering. My wife experiences this when she first starts driving. I tell her "little corrections" and that helps.
My favorite saying is: Let it be a motorhome
Mach428 is offline   Reply With Quote
Old 08-17-2018, 01:45 PM   #12
Garrette's Avatar
2014, 3170 DSF FORD E450 Sunseeker. Drove terrible from dealership. First, front alignment with cam bushings installed. Made the unit drivable.
2nd, a year later, replaced the steering stabilizer with Bilstein.
Alignment checked, Good
3rd 5 years later, replaced all shocks with Bilstein.
4th, 5 years later, replaced all tires.
Alignment checked, Good.
Each change Improved the steering incrementally. On our long trip, drives very well.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 08-19-2018, 11:30 PM   #13
kijak's Avatar
My little corrections are like a 4-5" movement in the steering wheel, I don't think that's normal???? I have a appointment Monday at the Ford Dealer to take a look at it. Do you think I'm just asking for too much, It gets to be fatiguing to drive 150 miles. do you think this is a correctable item? it's a 2018 Forester 3011, with 2500 miles on it.
Jack & Kim Blaydes
Old 08-20-2018, 10:00 PM   #14
Garrette's Avatar
Yes, you play is not normal. I had the same problem. You can do a crude check your self for front end play just by observing the wheel movement with the steering. The wheels should move the instant the steering wheel is rotated. With the RV started, Have someone just barely move the steering wheel while you observe the wheel movement.
An alignment is most likely the issue. Here is a link to the
FRF custom specs. Have it aligned to these specs. It will require replacing the straight Ford bushing with cam bushing. Not much money. Mine was $280.00 for everything, five years ago.
Alignments are best done with a trip load out but get it done anyway. You can always get it checked with a trip load out. Mine are aligned to these specs and there is no abnormal tire wear. I believe these specs were developed for the rental industry. There is a history.
Link to custom specs.
http://www.forestriverforums.com/for...ecs-61397.html
Let us know what the dealer says.
Old 08-21-2018, 08:29 PM   #15
Our 2017 2501TS on the E450 chassis handled decently from the factory, but wandered pretty bad when towing our Jeep (4 door Jeep lifted on 35” off-road tires, so that doesn’t help), when it was windy, or especially with both. Towing took heavy focus and if there was any decent wind it was pretty “white knuckle” and I’d be fatigued after a couple hours driving.
Probably could’ve gone with a front end alignment, but since it only happened with towing and/or wind, I decided to upgrade the steering stabilizer. Went with the roadmaster and it made a HUGE difference. No wander at all now and can drive it with one finger like a regular van. 55mph used to be the max we’d do when towing. Now sometimes I look down and realize I’m doing 70 (and then back off to 60-65 &#128541
Every once in a while I feel a little bit of wandering and think something is wrong until I check the weather and realize there’s 30mph gusts! 😂 Before 15-20mph gusts were downright miserable. No more pulling when a big rig goes by either.
Jpontheroad is offline   Reply With Quote
Old 08-21-2018, 08:36 PM   #16
We used to have quite a bit of play like that, but it typically was only when towing the Jeep behind us (with 35” knobby tires) or when it was really windy. Went with the roadmaster steering stabilizer and all that wander is gone. Might still need to have the front end alignment done, but since it was only happening when towing or with wind, it felt to me like oversteer caused by the wind and big Jeep tires wandering behind us a bit. Problem is solved now and it tracks straight when driving, braking hard, etc.
Old 08-29-2018, 11:55 PM   #17
kijak's Avatar
Just got mine back from the Ford Dealer, there Alignment computer went out, and a week later it's done, it is better but still room for improvement, and they wouldn't look at the air bags. mine don't hold air longer then a week From 70 down to 40 then hoover around 28. Still chasing that one.
Jack & Kim Blaydes
Old 09-01-2018, 10:50 PM   #18
Kirk S's Avatar
When we took delivery of our 3051 the air bags had 30 lbs in them. After loading (and weighing it) it didn't ride as well as before. We experimented and found for our use, 70 - 75 psi rides best.
I have to top them off before each trip and sometimes during a long trip. They will not stay at 70 - 75 psi for long and as you said, they hang around 40 and lower the more the rig sits. Must be the nature of the beast.
If you want a real eye opener concerning air bag pressure, put a TPMS transmitter on one and watch the wild up and down pressure swings, especially when turning. I had hoped to keep up with the pressure that way but the alarms were unnerving.
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
Old 09-02-2018, 05:00 AM   #19
RETIRED AND LOVING IT
n-e-d's Avatar
Tried that too...yikes
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Diesel Cargo Van HR DRW EXT DIY Daytripper "Red Roamer"
n-e-d is offline   Reply With Quote
Old 09-02-2018, 06:45 AM   #20
Citrus County, Fl.
GL1800Rider's Avatar
I have found that my air bags lose about 1 pound a day. I fill mine to about 72 but if we stay in one spot more than 10 days I pump them up before we leave. I have found that if you try to fill them with the jacks down it gives you a false reading.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
forester
