Old 11-24-2015, 07:28 PM   #11
Had my six volt batteries in for three years now and no complaints. The do last a lot longer, but as mentioned above, top up with distilled water every couple of months ( don't over fill ). Have heard that it helps to add a 325 mg aspirin to each cell every six months. Not sure if this is fact or not. I have been doing it and would like to hear from others on this.
kenenn is offline   Reply With Quote
Old 11-24-2015, 07:50 PM   #12
Pickin' & Campin'
Adding an asprin to a battery cell will create acetic acid which then reacts with the sulfuric acid to produce a short boost in battery voltage. It has long been a “McGuyver“ type of quick fix in the back country world of off roading.
One or maybe two asprins, more than just one time, is probably not good for the long term life of the battery.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 11-24-2015, 07:54 PM   #13
Bluepill's Avatar
Yeah, I always hate it when my battery says "Sorry dear, I have a headache"
2008 Itasca Meridian 37H
Old 11-25-2015, 04:41 AM   #14
Maybe one of the blue pills would cure it's headache.
Apologies to the original poster for diverting the thread to silliness.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 03-15-2016, 11:00 PM   #15
Originally Posted by jabba7 View Post
So my last camping trip, my coach batteries (12V) were dead, and wouldn't hold a charge. I tried to recharge them using a battery charger, but I believe one had a bad cell. I decided to purchase 2 Trojan T-105 6V batteries to replace them. I just got them installed, but I'm not getting any DC power to the motorhome. They are wired in series, just like they should be. I've included a picture, so maybe someone can take a look at it, and see if I did something wrong. Also, is there something else I should have done when changing from 12V to 6V batteries? I have a Forester 3171DS.
Sorry to ressurect an older thread, but I need to figure out batteries for the 2014 3171DS we recently picked up. On our TT I had gone to the 2x GC batteries and was very happy. Concerned about clearance under the steps in our new rig.
Is there enough depth to install them without modifying the compartment or lid? Did you have any other clearance issues with them?
Thanks!
vajeep is offline   Reply With Quote
Old 03-22-2016, 12:00 AM   #16
I measured our 2250 Sunseeker just after getting it - the width and length dimensions are fine but the depth is a gotcha. When I measured the GC batteries in our old unit and compared them with the depth in the step well, I found the batteries are within an 1/8" of the underside of the metal lid - not a good thing. Looking at battery sites, I'm finding some are even a bit taller than the available depth.
Before you invest in a pair of golf cart batteries, measure, measure, measure!
I have a couple of ideas for making them fit in the stepwell - but it's going to take a bit of metal work. I plan to drop the floor about an inch. Someday.
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
power, led, battery
