Originally Posted by n-e-d
nice job
+1 on the nice job.
I've been working on getting mine installed using somewhat the same approach as yours. I used an 8X8 Non Metalic, water tight enclosure I picked up off the shelf at Home Depot and included a 100 amp ANL type fuse in mine along with the shunt. Since I have two batteries mounted side/side on my trailer tongue I just mounted the box between them.
Have all assembled but am waiting for a day over 40 degrees and with no rain (rained straight here for the last 20 days with daytime temps high 30's, low 40's) to finish the final connections.
Still working out the final routing for the monitor cable and a #4 wire that will go to my converter.
Side note. since I have two batteries and a selector switch that allows me to isolate them if necessary, I have meticulously kept all wires between battery and switch, and battery to common ground point EQUAL IN LENGTH. This gives me as true a parallel connection as I can get with the only variations in resistance being the internal resistance of the individual batteries. Why? Because on paper it looks good and it was no big deal as I make my own cables. A $30 crimping tool that allows me to crimp all the way down to 1/0 terminals with ease. Looks like a set of bolt cutters only with crimping instead of cutting jaws. Some heat shrink in black or red and you can't tell one of my cables from one you might buy off the shelf at an A/P store (just a heck of a lot cheaper).
When I finish my project, all primary battery wiring up to the converter/distribution panel will be #4 with the exception of the tongue jack and slide motors. They connect directly to the battery (in a frame mounted J-box) with their own inline fuses so I'm not going to bother with them. All current from the battery(s) will still run through the shunt which will be the common ground for the batteries and 12 V system. Regardless of the number of grounds going to the frame, the power will still flow through the shunt.
I've changed my mind about running a direct cable from power panel to battery using #4 wire except for the negative connection on my Inverter. That said I'm upgrading the main negative connection to the frame from a ring terminal and self tapping screw to a regular panel type lug attached to a bare metal point on the frame with a much better self threading screw designed for grounding.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
