Old 12-06-2017, 07:19 AM   #1
Installing Battery Monitor
One of my projects that I am planning for over the winter is to install a Battery Monitor. Right now I am looking at the Victron BVM-700 as I already have a Victron MPPT solar controller and like how that is working and the Bluetooth connectivity option.
Question...how have you wired wired the monitor shunt connection if part of the load is directly connected to the battery and pulling power all the time (i.e levelers, BIM, etc) and the rest of it goes through the 12V disconnect?
newRVer is offline   Reply With Quote
Old 12-06-2017, 10:19 AM   #2
Fulltime family RVer
You should move everything AFTER the shunt. The only thing coming off of the negative side of the battery should be the shunt. Otherwise, your measurements will be inaccurate.
Old 12-06-2017, 04:03 PM   #3
Agreed. However, I am more interested in the logistics and wiring part of this project. Did other people install the shunt in the battery step well or somewhere else? Also, since I am considering a change in batteries, I might want to wait until I know what type of batteries (and dimensions) so I can plan the battery monitor install accordingly.
Old 12-07-2017, 04:37 AM   #4
RETIRED
n-e-d's Avatar
Installed Trimetric shunt in stairwell battery box. Plenty of room with original batteries
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "My Little Red Corvette"
n-e-d is online now   Reply With Quote
Old 12-07-2017, 07:58 AM   #5
After I had mounted my shunt to the frame by the batteries I found this innovative bracket that someone had made by flattening 3/4"copper tubing. Easy, safe and low profile. Should have done it myself that way.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 12-07-2017, 10:57 AM   #6
Wandering's Avatar
N E D. Can you share a picture of installed shunt. Planning to do the same.
Forester 2451s
Wandering is offline   Reply With Quote
Old 12-07-2017, 11:02 AM   #7
RETIRED
n-e-d's Avatar
Will try to get one by tonite
Mary and Me
2015 Jeep Cherokee
Old 12-07-2017, 02:02 PM   #8
Now that's an innovative approach assuming you have enough clearance above the batteries.
Old 12-07-2017, 02:05 PM   #9
I should mention that after getting a chance to read the installation instructions, this may be simpler than I thought. I.e. the shunt actually connects to the negative terminal.
Name:	shunt connection.jpg
Old 12-07-2017, 02:06 PM   #10
RETIRED
n-e-d's Avatar
Shunt is to the right of the box... I am looking down from top step
Name:	2017-12-07 13.53.05.jpg
Mary and Me
2015 Jeep Cherokee
battery
