Old 08-08-2019, 03:32 PM   #1
joel ritchie's Avatar
Instrument lights on E450 Forest river forester 3011 DS Class C
Does anyone have a fix for the dash lights. In the bright daylight you canít read the speedometer or any of the other gauges. I have tried to turn the lights on and turn the dimmer all the way up with no help. Is there a small set of lights you can put on the gauges to help. I had to use my flashlight today on the way home so wouldnít get a ticket. I use my gps but didnít have it today.
joel ritchie is offline   Reply With Quote
Old 08-08-2019, 05:53 PM   #2
Dennys67's Avatar
Same problem so I will be interested to hear about any fixes.
Dennys67 is online now   Reply With Quote
Old 08-08-2019, 07:19 PM   #3
A32Deuce's Avatar
I have a Scan Gauge mounted with Velcro on the top of the dash and one of the readings is speed. Easier to read up there with just a glance. Side Benny if the computer throws a code, you can read it. Works on any OBD2 system.
A32Deuce is offline   Reply With Quote
Old 08-09-2019, 11:38 AM   #4
Tombsy's Avatar
+1 on the Scangauge plus I use my Garmin GPS for speed as well. Iím in Canada and the kilometres scale on the gauge is unreadable itís so small the indicator needle covers 10kph on the gauge.
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
Tombsy is offline   Reply With Quote
Old 08-09-2019, 12:24 PM   #5
A32Deuce's Avatar
I like the scan gauge because its almost like a heads up display. I only have to glance at it.
Old 08-09-2019, 01:00 PM   #6
Chuck_S's Avatar
Ford E-series:
INSTRUMENT LIGHTING
DIMMER
Note:If you disconnect the battery or it becomes discharged, the dimmer switch will require re-calibration. Rotate the dimmer switch from the full dim position to the full dome/on position to reset.
Note:Move the control to the full upright position, past detent, to turn on the interior lamps. Move the control up or down to adjust the intensity of the panel lighting.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 08-09-2019, 02:13 PM   #7
e450
thanks chuck I did that. Donít if it did any good yet. Will see when I go out on next trip.
Old 08-09-2019, 02:17 PM   #8
What model of scangauge do you have.
Old 08-09-2019, 03:09 PM   #9
Chuck_S's Avatar
Joel --
For grins remove the Negative battery wire, let the system sit for a minute or two, and reconnect. This may reset the module that's controlling dash illumination. It'll brick your radio, though, so have the code handy. Won't cost you more than 10 minutes. And might just work.
Next stop is one of the Ford Truck forums -- lots of guys with E-series vans there.
-- Chuck
Old 08-09-2019, 04:27 PM   #10
Usually Confused Member
emm-dee's Avatar
Problem with using the dimmer is it only controls the instrument lights when the park/headlight switch is on. It works sorta OK but it dims the radio viewing screen to the point it is very hard to see the rear camera. My cam is pointed down to view the toad connection and front end. I use a ten inch iPad Pro for a rear traffic observation camera mounted on the Jeep so it has its own dimming feature.
So now, yíall got me thinking about a solution, which is really needed. The gauges are really hard to see in daylight. I cut a 12Ē strip of white LED lights, soldered some 24 gauge wire to it, dropped the wire down behind the panel trim and hooked it to a 9 volt battery. That is just a temporary setup which I will test to see if it works during my five hour drive on Sunday.
If it works then Iíll install a permanent wire and connect it to the chassis electrical system with a mini switch and fuse. I let yíall know the results Sunday night.
Hereís a pix. The reflection of the fuel and temp gauges is only visible to the camera...canít see it while seated and driving.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
class c, forest river, forester, light
