Old 09-02-2015, 03:00 PM   #11
interesting setup, must research now..
foretm is offline   Reply With Quote
Old 09-03-2015, 01:43 AM   #12
I have a Verizon 4G LTE that I take everywhere with me. It doesn't care if I'm in Silverton Colorado or the backwoods of Paris TX. our two laptops and I-phones work when other people have very poor or no reception. If my wife needs her laptop while I'll I'm driving, all we need is a power source. It work great for me.
Las Cruces is offline   Reply With Quote
Old 09-04-2015, 03:32 PM   #13
Can you tell me what model 3g/4g aircards you have and how they connect to your Wilson booster and to the wifi ranger? I'm researching this stuff and I don't see any new VZW hotspots that have both an external antenna input and a USB to connect to the wifi ranger. So are your aircards USB and your wilson extended has an external and internal antenna?
Old 09-04-2015, 04:00 PM   #14
Creativepart's Avatar
My Verizon aircard is the 6620L - it connects to the Wifi Ranger via USB cable. The WiFi Ranger is completely capable in controlling the aircard. And, the Aircard has a "tethering" setting in advanced settings that turn off the Wifi in the aircard so the WiFi Ranger's USB connection handles all the data.
My ATT aircard is a 770S and it too connects to the WiFi Ranger with a USB.
But, of course, you only use one of these at a time. And in my experience the Verizon works much better.
Both of these have an external antenna connector too - though I don't use it. My Wilson Booster is the older Sleek 4g "Cradle" booster. You simply put the aircard in the cradle and the booster does it's signal boosting through the proximity of the aircard.
Even the new cell boosters don't physically connect to the aircard. They don't have a cradle, but they have an indoor pad that rebroadcasts boosted cell signals into a 2 to 4 foot area around the indoor pad.
I would guess, that even without a booster, you would see some signal improvement from a ground plane attached hi gain antenna on the roof of your RV with the aircard plugged directly into the antenna. But I find the Sleek 4G cradle booster will take a one bar signal and make it 4 or 5 bars.
Here's some links:
Wilson Sleep 4g:
Amazon.com: Wilson Electronics Sleek 4g Kit - Retail Packaging - Black: Cell Phones & Accessories
Larger Cell boster without a cradle more db of boost and spreads the boosted signal all around the installed pad:
http://3gstore.com/product/5654_webo...-m_470108.html
Verizon 6620L
Amazon.com: Verizon MiFi 6620L Jetpack 4G LTE Mobile Hotspot (Verizon Wireless): Cell Phones & Accessories
ATT 770S
Unite (AirCard 770S) for AT&T, Routers, Antennas, Amplifiers, Repeaters and Accessories : 3Gstore.com
Antenna I use:
SureCall 12" Magnetic Mount Antenna (Adapter Cable Sold Separately) : 3Gstore.com
By the way, the Wifi Ranger can also connect to your aircard via the built in wifi in both devices. You don't have to use a USB connection - it's just better in every way to have the Ranger controling the aircard.
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 09-04-2015, 04:30 PM   #15
PSA -- I just saw that the 3GStore is offering 20% off of these items - but only yesterday and today. Using discount code: 48hourskingofrandom at checkout.
That's a pretty good deal. I purchased my Wilson booster from them and they were great to work with.
http://3gstore.com
PS. I have no connection or affiliation with them. Just passing on a deal.
Old 09-07-2015, 08:02 AM   #16
This is the missing link I was not able to figure out. In the documentation, it only refers to a test port, not an external antenna port, page 10.
http://cache.vzw.com/multimedia/mim/...fi6620l-ug.pdf
So I was confused as to how to boost the VZW signal, with a direct connection vs the external antenna and an internal "pad" or some type of non-direct signal boosting. I was leaning toward the direct path similar to how its done in this video from 3gstore.com, .
So it looks like the 6620L will allow for both USB tethering and an external antenna connection. I appreciate your help.
Lastly, the components used in the WiFi Ranger kits can be found here for a lot less if anyone is interested.
RouterBoard.com : RB951Ui-2HnD
RouterBoard.com : Metal 2SHPn
With these you get everything you would get from WiFi Ranger FM kit, with the exception of the mounting bracket. The two items above retail for about $160, a hefty discount.
- Mike
Old 09-07-2015, 08:53 AM   #17
I should say that I'm assuming that the 6620L has an external antenna connection - It looks like every external antenna connector I've ever seen. But since I'm not using it, I haven't paid it much attention. But it looks just like the connector in the video you embedded.
Those two wifi items appear to be the exact same thing as the WiFi Ranger - but I wonder if they would work the same without the Go2 firmware.
When I access the set up in my Go2 I have a control panel with a ton of very helpful options. Such as being able to prioritize connections - making the unit use Wifi rather than cellular broadband when ever possible. Plus, I'm able to enter an unlimited number of wifi connections - for every campground or wifi we log onto - so that the Go2 connects automatically to each network automatically. The best part of this is that I set up the Go2 to log on, but all of our devices have just one universal log on to the Go2.
Plus there are a great many other firmware features that make the Go2 really ideal for RVing.
I can see that the hardware is the same - it's the firmware/software that I'd be curious about. Who knows, it might be all there. But how to know that?
Here's the control panel of the Go2:
Name:	Screen Shot 2015-09-07 at 8.51.59 AM.png
Old 09-07-2015, 11:44 AM   #18
Fulltime family RVer
There are a lot of alternatives to the expensive Wifi Ranger and a lot of people will tell you "this is the same thing without the price tag"- but very few have actually ran them side by side.
IMO, where the wifi ranger excels is in its convenience and "no fuss" setup and configuration. To me, my time is well worth the added expense. Others have good luck with other products- to each his own.
ependydad is online now   Reply With Quote
Old 10-05-2015, 05:43 AM   #19
Great information, I'll sure I'll be back with lots of questions. Thank you for the awesome post.
2007 Work & Play 34RL Toyhauler.
2003 GMC Sierra HD Dmax Alli.
036.6turbo is offline   Reply With Quote
Old 10-05-2015, 10:42 AM   #20
So, I've been using this system for the past month on this month long 3,500 mile trip and I have some comments about it.
The handiest part of the system is the Go2 Router with USB tethering. We've been staying in RV Parks with free wifi OR in State Parks without any Wifi. When the park has decent wifi with plenty of access points the big powered antenna on the roof isn't much use - and many times it creates problems because it's so powerful.
For instance, we spent 2-weeks at a park outside Washington DC and they had good wifi and the park's access point was about 20 feet away. I was having the devil of a time getting the system to work reliably until I unplugged the 2-mile powered antenna on the roof.
Then I just used the Go2 routers built in antenna to pick up the park's wifi and broadcast it in our RV.
And, in the State Parks without wifi, the 2-mile antenna couldn't find any wifi except the broadband cards of the other campers - and they are always password protected. So, the Go2 just used my broadband aircard that is attached to the Go2 with a USB cable.
If you boondock a lot, and park at Walmart etc, the powered roof top antenna's massive range could be a real help - but if not I'd suggest getting their cheaper $350 "Mini" system that includes a rooftop antenna that only reaches .5 mile and has a smaller indoor router with all the same features.
We've been able to use this system to watch Netflix, a little. Mostly there are halts and stalls and it's frustrating.
But we've had excellent internet access.
Without this system, when you go to a new RV park you have to log on to the parks wifi separately on all of your devices - phones, tablets, and computers. And as you move from one RV Park to another you have to log all of these devices on separately.
But with this system, you set up the Go2 router with one network id and password. Then you set up all your devices to use those settings. Then you never have to do that again. The only thing you do when you get to a new RV Park is enter the RV Parks wifi settings into the Go2 and you're done. So, for us instead of setting 5 or more devices at each RV Park. We only have to do it once on the Go2.
Here's a link to Wifi Ranger's smaller simpler and cheaper system:
Mini Pack
forester, modifications
