Old 10-14-2016, 07:53 PM   #11
Sunseeker 3010DS
Not an expert on Inverters but I would guess if you need 400 watts for any length of time your gonna take a prety good bite out of your batteries? thus needing to run the gen to recharge anyway. Unless you need is while driving but that may require a bigger alternator?
slamac is offline   Reply With Quote
Old 10-14-2016, 08:00 PM   #12
Citrus County, Fl.
GL1800Rider's Avatar
Not sure what your needs for an inverter are, but your tv's are all 12 volt
2016 Forester 3011DS
2015 Toyota Corrola S toad
99 Terry 31G
GL1800Rider is online now   Reply With Quote
Old 10-15-2016, 09:48 PM   #13
Frank & Eve's Avatar
DH uses a CPAP we have a 400 and a 600 watt inverter. He uses one or the other when we boondock at Walmart. Hardly shows any battery drain after 8hrs use.
Frank & Eve is online now   Reply With Quote
Old 10-18-2016, 09:55 PM   #14
kdwallin's Avatar
Have been faithfully reading all these posts, but I still don't quite get what situation would benefit from adding an inverter on top of existing power in my new 2401W. Granted, I am new to RVs, so must be missing something. Is it a boondocking need? Thanks for continued enlightenment!
Kelly & Mary Beth
2017 Forester MBS 2401W
Kelly and MB
2017 Forester MBS 2401W Class C motorhome
kdwallin is offline   Reply With Quote
Old 10-18-2016, 10:08 PM   #15
Originally Posted by Mach428 View Post
Now THAT'S what I'm talking about. Would you please share brand, where you bought it, mounting, etc
Be advised that if you go for a 400 watt inverter, that's equivalent to 33 amps at 12VDC. You will need to run at least #10 wire from your battery to the inverter to power it. Most cigarette lighters have 20 amp fuses.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
Old 10-18-2016, 10:28 PM   #16
Bluepill's Avatar
Kelly & Mary Beth
A small inverter (100 Watts or so) is good for recharging laptops, cell phones, Tablets, etc. that have 120 volt plug-in power supplies.
If you are connected to shore power or run a generator, the inverter is not needed.
2008 Itasca Meridian 37H
Old 10-18-2016, 11:08 PM   #17
kdwallin's Avatar
Got it ... thanks so much, Bluepill!
Kelly & Mary Beth
Kelly and MB
Old 10-19-2016, 12:40 AM   #18
I suppose the biggest reason for an inverter is that I didn't want to run a generator all night just to power my c-pap
Mach428 is offline   Reply With Quote
Old 10-19-2016, 06:05 AM   #19
RETIRED
n-e-d's Avatar
Location: Home of the 4 time Super Bowl Champions Patriots and we'll be there again
Mach428 have you looked into a 12v adapter? I have an Intelipap that I ordered with a 12v adapter . It uses minimal power while dry camping and I have also run it off my jump starter
Mary and Me
2015 2650s
2015 Jeep Cherokee
n-e-d is online now   Reply With Quote
Old 10-19-2016, 06:49 AM   #20
lgray's Avatar
Our Winnebago Aspect, class C, has a 1,000 watt inverter with two NAPA house batteries to support it. That being said, it is rarely used.
lgray is offline   Reply With Quote
inverter
