Old 10-14-2016, 03:15 PM   #1
Inverter Question
Hi folks. I'm new to this forum as I've just purchased a 2012 FR Forester 3011DS. I cannot find anything about an inverter. I thought these were standard. Is it possible my MH doesn't have one?
Mach428 is offline   Reply With Quote
Old 10-14-2016, 03:22 PM   #2
Citrus County, Fl.
GL1800Rider's Avatar
It does not have an inverter as there is no residential refrigerator.
If you are talking about the "converter" it is a Progressive Industries and is part of the electrical panel at the foot of the bed where your breakers are. There is a green light that flashes about once every 4 seconds when the converter is maintaining the battery on float mode.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is online now   Reply With Quote
Old 10-14-2016, 03:32 PM   #3
Thanks for the reply. I thought there was a built-in inverter (like I have on my 2016 Tacoma) that would invert 12V to 120V for small wattage electric devices
Old 10-14-2016, 03:34 PM   #4
Sunseeker 3010DS
Yep, everything runs on 12 volt DC except the microwave and Air con if you need AC power run the generator. It can be run while driving down the road. Might nick your fuel economy a bit. but whats another few gallons per mile anyway
slamac is offline   Reply With Quote
Old 10-14-2016, 03:36 PM   #5
Got it. Thanks much
Old 10-14-2016, 03:40 PM   #6
Sunseeker 3010DS
If you want a very low wattage inverter you can buy the ones that plug into your 12 volt power source ( cigarette lighter) for under $20.00
Old 10-14-2016, 03:44 PM   #7
Sunseeker 3010DS
Check Amazon there are a lot to pick from ranging from Around $15.00 to over $100.00
Old 10-14-2016, 03:52 PM   #8
Okay. Thank you
Old 10-14-2016, 05:48 PM   #9
bikendan's Avatar
I hard wired a 400w inverter to the battery, for tv, dvd and electronic devices.
Equalizer WDH
Old 10-14-2016, 06:46 PM   #10
Now THAT'S what I'm talking about. Would you please share brand, where you bought it, mounting, etc
Old 10-14-2016, 06:53 PM   #11
Sunseeker 3010DS
Not an expert on Inverters but I would guess if you need 400 watts for any length of time your gonna take a prety good bite out of your batteries? thus needing to run the gen to recharge anyway. Unless you need is while driving but that may require a bigger alternator?
Old 10-14-2016, 07:00 PM   #12
Citrus County, Fl.
Not sure what your needs for an inverter are, but your tv's are all 12 volt
99 Terry 31G
Old 10-15-2016, 08:48 PM   #13
Frank & Eve's Avatar
DH uses a CPAP we have a 400 and a 600 watt inverter. He uses one or the other when we boondock at Walmart. Hardly shows any battery drain after 8hrs use.
Frank & Eve is offline   Reply With Quote
Old 10-18-2016, 08:55 PM   #14
kdwallin's Avatar
Have been faithfully reading all these posts, but I still don't quite get what situation would benefit from adding an inverter on top of existing power in my new 2401W. Granted, I am new to RVs, so must be missing something. Is it a boondocking need? Thanks for continued enlightenment!
Kelly & Mary Beth
2017 Forester MBS 2401W
Kelly and MB
2017 Forester MBS 2401W Class C motorhome
kdwallin is offline   Reply With Quote
Old 10-18-2016, 09:08 PM   #15
Be advised that if you go for a 400 watt inverter, that's equivalent to 33 amps at 12VDC. You will need to run at least #10 wire from your battery to the inverter to power it. Most cigarette lighters have 20 amp fuses.
2011 Traverse LT, 3.6L, FWD
Old 10-18-2016, 09:28 PM   #16
Bluepill's Avatar
Kelly & Mary Beth
A small inverter (100 Watts or so) is good for recharging laptops, cell phones, Tablets, etc. that have 120 volt plug-in power supplies.
If you are connected to shore power or run a generator, the inverter is not needed.
Old 10-18-2016, 10:08 PM   #17
kdwallin's Avatar
Got it ... thanks so much, Bluepill!
Kelly & Mary Beth
Kelly and MB
Old 10-18-2016, 11:40 PM   #18
I suppose the biggest reason for an inverter is that I didn't want to run a generator all night just to power my c-pap
Old 10-19-2016, 05:05 AM   #19
RETIRED AND LOVING IT
n-e-d's Avatar
Mach428 have you looked into a 12v adapter? I have an Intelipap that I ordered with a 12v adapter . It uses minimal power while dry camping and I have also run it off my jump starter
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Diesel Cargo Van HR DRW EXT DIY Daytripper "Red Roamer"
n-e-d is offline   Reply With Quote
Old 10-19-2016, 05:49 AM   #20
lgray's Avatar
Our Winnebago Aspect, class C, has a 1,000 watt inverter with two NAPA house batteries to support it. That being said, it is rarely used.
lgray is offline   Reply With Quote
inverter
