Old 06-13-2013, 02:04 PM   #1
Inverter question 3051S
What does the inverter power on a 3051S? Thanks for the help.
jblmnt is offline   Reply With Quote
Old 06-13-2013, 02:38 PM   #2
Power Converter 12 volts
My 2013 Forester #3051S has a Power Converter (WFCO Ultra III WF-9800 Series). It supplies 12 volts to the RV when on shoreline or I assume generator power. If you shut-off your 12 volt main disconnect switch the Converter is still powering your RV. But, I always leave on the house battery switch as it is required for charging to take place.
Tim
2013 Forester #3051SF
2009 Toyoda Tacoma (toad)
2010 Newmar Dutchstar (Sold)
2011 Fleetwood Bounder (Sold)
trwmodela is offline   Reply With Quote
Old 06-15-2013, 12:16 AM   #3
bikendan's Avatar
which are you talking about, an inverter or a converter.
all RV's have converters but only a few come with an inverter, usually large motorhomes.
Old 06-15-2013, 07:01 AM   #4
My Class "A" diesel had a 2,000 watt inverter that would power all outlets and the refrigerator while driving down the road. I have seen small inverters in some Winnebago Class "C" models that power one outlet near the inverter. There are a lot of options if you want to add an inverter just make sure your house batteries can handle it. I will just use my generator if necessary.
Tim
