Old 10-01-2016, 10:35 PM   #21
rracer5's Avatar
They will be on the chassis itself before they go up into the coach.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 10-03-2016, 04:33 PM   #22
Creativepart's Avatar
Problem solved, lesson learned.
So, I was just reading the other day about problem solving and how it's always best to not over think things and to start with the simplest possible solution FIRST.
When I checked my taillights the other day when connecting the toad ALL FOUR of the stop/tail/turn lights on the back of my RV were non-functional. So, in my mind the most logical thing to cause all 4-lights to go out "at once" was a Fuse. So for a few days I churned around looking for the right fuse and the right fuse location. We even cut short visiting a national landmark by about 2-hours so I could unhook the toad and go to the nearest auto parts store to get the correct fuse.
But that had no effect on the issue.
The next thing was the wiring harness where it travels the chassis to the rear of the RV. It was raining for 3 or 4 days so I put off crawling under the RV to check the wiring. I did check it today and no problems were found.
I decided to remove the entire tail light assembly to check it out and it was sealed in place so well I was having trouble getting it removed. So, I took off the tail light lens to find a way to tug on the assembly - HELLO? What's this? The bulb was shattered.
I removed all four of the lenses and sure enough all three of the other bulbs were shattered as well. In post #3 of this thread "rambler guy" told me to check those and he had had the exact same thing happen to him. But noooooo, I had to waste everyone's time, drive 350 miles without taillights on the RV and crawl around under the dashboard, the hood and the RV searching for what I was sure was the problem.
It did look like all the bulbs had shattered due to water and there was a day just before this all started where we drove in pouring rain with the headlights on - which would have heated those lamps up really well and any water on them would have made them shatter.
So, what did we learn here?
1. Don't be a dope
2. Listen to RamblerGuy
3. And ALWAYS start at the easiest solution first
Quick trip the auto parts store and I bought 4 LED replacements for the 2057 bulbs and a tube of exterior sealant. I sealed all 4 of those lenses and I have stop/tail/turn lights again. Oh, and I checked the only working lights, the backup lights, and I sealed those lenses too just for good measure.
Thanks to all that helped and please let me apologize for wasting everyone's time with this trivial non-serious issue. And thanks to RamblerGuy for telling me how to fix this right away.
PS. One last thing - I suggest you remove all of the Clearance lights on the front/top of your cap and seal all of those with silicone... and then do the tail light lenses too. I have now had issues with both of these things during my first 15 months of ownership and clearly, they are not water tight as they should be. Simple dose of prevention there.
2015 Forester 3051S
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 10-03-2016, 06:32 PM   #23
rracer5's Avatar
2014 Sanibel 3250
Old 10-03-2016, 06:44 PM   #24
Creativepart,
You did the easiest thing first - fuses. You just didn't have info telling you where to look, and asking in this forum was a good place to start.
I have many tales of overlooking a simple solution until hours or days have been wasted.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
RamblerGuy is online now   Reply With Quote
Old 10-03-2016, 07:38 PM   #25
Originally Posted by RamblerGuy View Post
Creativepart,
Agree with you on this , but the first rule of electrical testing is start at the last piece of the circuit, which in this case is the tail lights, and with a test light and see if you have power. If this had been done the blown bulbs would have be seen. Glad the problem has bee fixed though.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
ford, forest river
