Old 06-23-2015, 04:42 PM   #11
We have a 2015 2608ws with 15k a/c. We live in Fl and travel our west and it barely keeps us cool. We use fans. My advice, when and where you travel is to go with the larger option. Mind you this means other devices you operate will be limited but in my opinion to be comfortable, especially trying to get to sleep it will be worth it. My next will have 2 a/c's for sure.
robbdrell is online now   Reply With Quote
Old 06-25-2015, 08:06 AM   #12
37 ft Silverback in Florida RIGHT NOW. Dual AC's run day and half the night. Set both on 80 degrees to avoid freeze ups. You can NEVER have enough cold air when you need it! You cannot cool these units down from a git go when it's 90 degrees plus.
Does not matter it it is a Winnebago, Forest River, etc. they lack insulation that a home has....period! If you ever see a $ million dollar plus Prevost, they have 3 or 4 ac units plus dash air. I would guess they are better insulated than the avg $70,000 retail unit.
Start early in the day and let er run!!
don't worry, be happy!! 😄
These things are great versus the old models, BUT, they are boxes on wheels.
Be safe and travel healthy. Enjoy our beautiful USA.
SilverbackMel is offline   Reply With Quote
Old 06-25-2015, 08:24 AM   #13
Mddle of the Rd Extremist
MeepMeep's Avatar
Get the bigger unit.....it'll work less and last longer. Besides, you never know where or when you'll end up camping in a different climatological zone and might actually use the HP or the extra AC capacity. I suspect it would also be cheaper to do it up front rather than retro-fit later
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 06-25-2015, 10:48 AM   #14
Sagecoachdriver's Avatar
spoke with AC tech
I spoke with an air conditioning tech about the 13,500 vs 15,000. He said there is only a 10% difference in capacity. 1 ton of A/C is 12,000 btu's and normally cools 500 square feet of floor space in homes and offices. My motor home will be no more than 300-350 square feet.
He said, motorhomes are terrible when it comes to heat gain and loss. Cab windows, metal doors and living space windows probably account for almost all of the problem. Along with family going in and out the door.
So the 10% differnce would be marginal and that's why they add a second A/C unit to gain another 15,000 btu''s. Doing more to insulate the cab from the living space, placing sunscreens on the cab windows along with the living space windows and cracking open a vent or two to allow the warmer air at the ceiling to escape will far exceed the 10% difference. The 15,000 unit will have shorter cycling than the 13,500 but not so I would notice it.
Trying to cool down an RV that has direct sun hitting a large window and cooking the cab will be impossible. Any cooling effect will be quickly lost to the radiating heat from the window. Best senario would be to drive with sunscreens in the living area windows and run the generator and both A/C units (roof and dash). this would allow the A/C to have a jump of sorts when we arrive at our destination. However, there is still loss from the cab windows.
Makes sense to me.
Sagecoachdriver is offline   Reply With Quote
Old 06-25-2015, 11:20 AM   #15
RETIRED
n-e-d's Avatar
Hey Sagecoachdriver enjoy your rig when it comes in. I'm sure it'll be fine.
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "My Little Red Corvette"
n-e-d is online now   Reply With Quote
Old 06-25-2015, 11:35 AM   #16
Witch Doctor's Avatar
Makes sense to me.
Used to design HVAC, we always used 300 sq ft. per ton. Now that is for a well insulated house air tight. This was in California. I agree with your senario. The only way you can cool these things when it is over 90 is to live like your in a cave. Windows are the big killer as you stated. I don't care if they are duel pane or not. All my windows came tented. It helps but if you put your hand by them with the shades pulled you can feel the heat gain. I think the walls are R-9 also the roof. Not much at all. I tried this at home on a 90 plus day. With the 3 slides pulled in my unit would cycle, 15,000 btu's. With the slides out the next day pretty much the same exact condition, the unit ran all afternoon without cycling at all. I will never buy another 5th wheel without 2 A/C's.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 06-25-2015, 11:54 AM   #17
B and B's Avatar
Same trailer as Glenn's. Same experience. Get 2 AC's. We also live in the North and have it cooler but a Diamond edition can not keep up with dark surfaces.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 06-25-2015, 12:14 PM   #18
The Forester 2701 isn't designed to handle 2 A/C units. We dry camp 90% of the time and the Onan 4K will not handle the load. Plus the A/C unit is right in the middle of the MH. WE are going to insulate ourselves from the cab and probably the cabover too as it's not going to be used. since it's ducted, I can also close the vents to the cabover and bathroom and even the bedroom area and close it off. I think it will be fine. I could also replace the unit with a 15,000 later and sell mine to my neighbor whose A/C went out. But as the tech said, there isn't that much additional cooling capacity between the units.
Old 06-25-2015, 12:24 PM   #19
Phat Phrog Stunt Crew
elind's Avatar
We have a 38' FW with 3 slides and when we only one 15,000 A/C on hot days it just wouldn't cool down. We added a second 13,500 A/C in the bedroom and made the difference. Plus in the evenings we needed to only run the one in the bedroom. That helps if your long term and paying the electric bill.
2014 Wildcat 327ck
elind is online now   Reply With Quote
Old 06-25-2015, 12:52 PM   #20
According to the domectic specks your 4.0 generator would carry to 13,500 btu A/C's. But as always it your decision but here is the info from them below, look at the bottom about generators:
S
57915.421 57915.521 57915.621 59016.621 59516.601
MODEL NO. 57908.521 57912.621 57915.426 57915.526 57915.626 59016.626 59516.606 600312.321 600312.421 600315.321 600315.421
Nominal Capacity (BTU/HR) * 7,100 11,000 13,500 13,500 13,500 15,000 15,000 11,000 11,000 13,500 13,500
Electrical Rating 115 VAC, 60 Hz., 1 ph.
Compressor Rated Load Amps 6.6 8.5 11.5 12.1 11.0 12.9 12.9 9.5 10.7 12.4 11.5
Fan Motor Rated Load Amps 2.5 2.5 2.5 2.5 2.5 2.5 2.5 3.1 3.1 3.1 3.1
Compressor Locked Rotor Amps 34.0 48.3 50.0 59.0 54.4 71.0 71.0 53.0 50.0 60.0 50.0
Fan Motor Locked Rotor Amps 5.8 5.8 5.8 5.8 5.8 6.0 6.0 8.8 8.8 8.8 8.8
Heater Amps/Watts @ 120VAC NOT AVAILABLE ON THESE MODELS 12.7/1530 NOT AVAILABLE
SCFM-High Speed Max./Min. 325 / 250 350/250 335/250
Total Static - Min/Max. 0.55 / 0.90" W.C. 0.40/1.10 0.12/0.65" W.C.
Refrigerant R22 Charge ( Oz.) 17.0 16.0 13.5 16.0 16.0 26.5 31.0 16.5 16.0 15.5 17.0
Minimum Wire Size ** 12 AWG Copper Up to 24 ft.
AC Circuit Protection 20 Amp Time Delay Fuse or 20 Amp HACR Circuit Breaker
DC Circuit Protection Installation must comply with all National, State, Providence, and/or local Electrical Codes
Installed Weight (Pounds) 75 94 100 94 94 101 102 95 101 96 102
Minimum Generator 1 Unit 2.5 KW 3.5 KW 2.5 KW 3.5 KW
Size *** 2 Units 4.0 KW 5.0 KW 4.0 KW 5.0 KW
59016.521
59016.526
59516.501
59516.
The 4.0 is for 2 units 13,500 and the 5.0 is for 2-15,500 btu units.
3500, 500, forester
