Old 05-23-2016, 04:26 PM   #1
Is there a trick to checking rear tire pressures
Anyone know of a way to check the rear inside tire pressures. Neither of the inside tire extenders work at all. We can't get a reading.
13STL is offline   Reply With Quote
Old 05-23-2016, 07:54 PM   #2
Commercial Member
HERE is a blog post on hose extenders. Note the outer ends are firmly attached (pop rivets)
You can send me email if you need faster reply. Email is posted under my picture on the blog.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 05-23-2016, 08:07 PM   #3
Could not open your blog post.
Old 05-23-2016, 08:32 PM   #4
Commercial Member
Sorry. Try it now.
Old 05-24-2016, 01:57 PM   #5
Mgs Forrester valve stems
If they are still using the limp fiberglass valve stems, ditch them and get steel. The originals were nothing but trouble.
john.tucson is offline   Reply With Quote
Old 05-24-2016, 03:55 PM   #6
Chief tinkerer
Gidyupgo's Avatar
13STL, my dual extenders wouldnt let me check pressure either. I took my extenders off and use a truck chuck/gauge with a straight end. Works great to check and add air. The simulators had to come off to get my hand through to remove them, but once off, I put the factory caps back on and reinstalled the sims. I can now check and add with Sims on.
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 05-24-2016, 04:24 PM   #7
I use extenders, but in a different way. On our old Four Winds/Ford, it had the tiny "hand" holes (The ford "engineer" who came up with these should be made to check every RV in the world) so I had to come up with another method without using permanently installed extenders.
Here's the tools:
Short permanent extension on outer dual - I had rubber valves, so I added a small support wire:
View through the "hand hole" to the inner dual schrader valve:
Using the length of 11/32" rubber hose, remove the cap:
Cap removed:
Using the long neck dual foot valve gauge, check the inner dual:
If the tire needs air, screw on the extension. The female end is fixed, so it can be rotated using the hose:
Extension attached:
Attach your compressor and fill to the desired pressure + a pound - it helps to have a screw fitting, rather than the press-on style:
I add a pound extra to compensate for the lost pressure when unscrewing the compressor/extension fittings.
I put the same style extension on the outer dual of our new Sunseeker and will use the same process. I have the new Pacific Dualies wheel liners, and the hand-holes are about half of the size of the original GM hand-holes:
Hope that helps!
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
Old 05-24-2016, 05:14 PM   #8
Commercial Member
brucemc
Very good job of addressing the poor design. Valve support are good temporary fix till metal stems are installed in the wheels. Few people think of the stress they are placing on valve stems when they push on it with pressure gauge or air chuck.
One suggestion. Change the caps from plastic to metal. If the core develops a leak the plastic will not retain your 80 psi but metal caps with internal O-Ring should.
Old 05-24-2016, 05:25 PM   #9
Our new Sunseeker has all metal caps - and we no longer own the Ford... so that is the new owner's issue.
Also, the Sunseeker has metal stems as, I suspect, they are part of the TPS system.
2016 2250LE/Chevy
Old 05-24-2016, 07:44 PM   #10
Brucemc, Thank you! Very informative and helpful.
pressure, tire
