Old 08-12-2015, 07:12 PM   #1
Jensen TV problem
We have a 32 in jensen 12 volt TV in living that won't stay on,I have a power supply cord on order but been 2 weeks without TV,still under warranty but long way from dealer. Thanks for any in put
oakie47p is offline   Reply With Quote
Old 08-12-2015, 07:37 PM   #2
gashog's Avatar
How long does it stay on before it turns off? Maybe the sleep timer is set for that length of time. Sleep Timer Allows you to set up the sleep timer : 5min, 10min, 15min, 30min, 45min, 60min, 90min, 120min, 180min, 240min and off.
1. Press the POWER button to turn the LED TV on.
2. Press the MENU button on the remote control to display the Main menu, and use the LEFT and RIGHT buttons to select the TIMER.
3. Use the UP and DOWN buttons to highlight an individual TIMER option, use the LEFT and RIGHT buttons to change the setting, and press the MENU or EXIT button to exit.
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 08-12-2015, 07:41 PM   #3
It use to stay on for several minutes,now it powers on flickers right back off,nothing..
Old 08-12-2015, 07:50 PM   #4
gashog's Avatar
OUCH,, I was hoping it was in your Timer Setting... Sometime it's faster and easier to contact the Manufacture https://www.contacthelp.com/Jensen/customer-service..
Phone: 800-645-4994
Old 08-13-2015, 06:49 PM   #5
Boso's Avatar
Does your little red light come on and off when you wiggle the line up at the 12v plug ? Mine was loose connection at the plug ,replaced plug it now stays on .Dealer ordered one and I also had one shipped to me in a hurry now have an extra for any of the three tv's
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 08-13-2015, 07:00 PM   #6
Yep red light will go off/on when jiggled. It does seem awful loose. I ordered a new power supply cord,hope that helps.Is the cord the plug you replaced? Thanks for input
Old 08-13-2015, 07:11 PM   #7
Boso's Avatar
Loose power cord
Yes the end of the cord doesn't expand like it suppose to it was a warranty item but I was in a hurry and ordered one and CW replaced the cord also probably will need an extra before to long
Old 08-15-2015, 03:40 PM   #8
Garrette's Avatar
2 days from Amazon Prime. And order 2, you will need them. I always keep a spare.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 08-15-2015, 03:46 PM   #9
Garrette's Avatar
Name:	ImageUploadedByForest River Forums1439671589.206298.jpg
Old 08-17-2015, 06:02 PM   #10
I replaced my 12 volt power adapter because it melted! Ordered the Jensen 12 volt to 110 volt power supply. This works fine and I do not worry about a fire anymore. BTW...I just met another Forester owner who's 12 volt power adapter for his 32" Jensen TV also melted.
Tim
2013 Forester #3051SF
2009 Toyoda Tacoma (toad)
2010 Newmar Dutchstar (Sold)
2011 Fleetwood Bounder (Sold)
trwmodela is offline   Reply With Quote
Old 08-17-2015, 07:23 PM   #11
Boso's Avatar
Glad mine was just a bad cord end yours must be overheating for some reason you would think the fuse would have blown if the wire got that hot
Old 08-17-2015, 09:24 PM   #12
Garrette's Avatar
What happens is the little button on the end will loose spring tension causing the button to heat up. It will slowly melt itself to a condition that the button will not make contact. My 32" TV is on its second one. If it melts #3, I may hard wire it in.
Old 08-21-2015, 07:57 PM   #13
Bought a new power supply cord,TV working,must have melted like you all stated..Thanks
Old 10-03-2015, 06:59 AM   #14
We also had problem with 12 volt tv adapter melting. Jensen sent us a new one but have not tried it out yet.
kenjoan is offline   Reply With Quote
jensen
