Old 09-22-2015, 03:01 PM   #1
Just Ordered a new 3011DS
We just got back from the RV show in Hershey and have good news to report, we came home with a new RV on order!
While we wanted to go to the show, it was not necessarily to buy or order and RV but we did know that was a possibility. I have been looking for about 8 months and had narrowed down to the possibilities to a few units. This was a good opportunity to see all of them at the same place and to compare likes and dislikes.
Recently I have tried to get the best pricing as possible from some of the internet dealers and thought that may end up being the final choice however I was able to find a dealer at the show that was close to home, provided a very competitive price and will be able to deliver the unit next spring so I donít have to worry about storage and insurance costs for this winter.
Itís interesting how one finally arrives at a decision as it usually takes a few twists and turns, but in short there were a couple of things that I found out along the way that helped narrow it down.
I first started looking at used units (14/15ís) and found out that most of them were priced at a point which made buying a new unit preferable since the cost differential was only about 10%. At a 20-30% discount I may have went the other way. Iím still trying to rationalize the minimal cost difference, and maybe if I had been willing to continue looking for another 6-12 months I might have found a seller who owned a clear title and would be more willing to negotiate. In the end I wanted to go into this winter knowing that I had a rig ready to go when the weather gets nice next spring.
Second question was to buy a 15 off the lot and/or order a 16. The show actually helped in this case as I could see some of the 16 changes in person and then make a call. Some of the things that did change or I know about for the 16 are;
  • New 6 speed transmission
  • New Jensen audio entertainment system in the coach (No longer need to use dash unit)
  • DVDís on main coach TV now play through coach system and not through Dash system.
  • New larger speakers outside that are connected to inside system. (These do not connect to outside TV)
  • USB/AC connections in bedroom are now mounted on bed platform vs wall or cubby.
  • Side view cameras are now mounted on outside of coach (no longer in mirrors)
  • No more window in Bed slide, rear window is now emergency exit.
  • Windows shades are now room darkening roller units
  • Rear taillights are LED
There may be a few others that I did not detect and will probably find when I take delivery, but these were the noticeable ones. Iíve attached some pics so you can see some of the differences.
Now we get to start planning our first RV road trip!
ID:	89582   Click image for larger version
ID:	89583   Click image for larger version
ID:	89584   Click image for larger version
ID:	89585   Click image for larger version
ID:	89587   Click image for larger version
newRVer is offline   Reply With Quote
Old 09-22-2015, 03:37 PM   #2
vwexpert's Avatar
I think GL1800rider and I convinced FR to delete the window from over bed.
1971 20ft fireball (too small)
1987 27ft Tioga (bad brakes / tires)
1998 36ft Discovery (rattles / air leaks)
2005 37ft Monaco Knight (lemon Lawed)
2008 40ft Monaco Diplomat (too big)
2016 Forester 3011 (ordered June 8th - Born Aug 6) IT'S HERE
vwexpert is offline   Reply With Quote
Old 09-22-2015, 03:53 PM   #3
That's what I heard!
Old 09-22-2015, 05:08 PM   #4
Citrus County, Fl.
GL1800Rider's Avatar
And the pull down black out shades! Looks like the light by the door is an LED now
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 09-22-2015, 08:49 PM   #5
vwexpert's Avatar
I got the led light on the left side but the regular amber porch light.
Old 09-23-2015, 07:45 AM   #6
Yes that light is now LED. (Added to the list)
Old 09-23-2015, 08:15 AM   #7
Georgia Rally Coordinator
aceinspp's Avatar
Congrats on your new order. Hope you enjoy Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 67
Old 09-23-2015, 12:17 PM   #8
What type of slide do they now have in the bedroom slide, I have a 2012 that had a few problem. I really like that no window change.
Bob B
rbreen1 is offline   Reply With Quote
Old 09-23-2015, 02:33 PM   #9
Citrus County, Fl.
The bedroom slide is still a Schwintek. I think a lot of those that have issues with them don't hold the button down for about five seconds after the slide extends and retracts to sync the motors. So far mine works flawlessly.
99 Terry 31G
Old 09-23-2015, 02:49 PM   #10
My problem was just this year. The wire that runs down from the motor to the controller under the bed was routed with a "U" bend in it at bottom of the wire going back up under the bed. After two years of road vibrations the plastic wire hold down clamp chaffed the wire and caused one motor to stop and go causing the slide to twist and jam up. It took me a long time to discover this problem, after just taking the bend out of the wire the slide has worked perfect. There is a whole discussion on this forum about problems with this slide.
Congats on the new one, you may have me looking again.
