Old 01-08-2019, 10:39 AM   #1
Campincarters's Avatar
LCI Panel Generator start
I have a 17 3011 DS with a LCI Panel. To start the generator do you hold the on button for about 10 seconds to prime it or the generator icon. It takes about 4 or 5 times to start it to get it running. I am thinking I am doing something wrong.
Campincarters is offline   Reply With Quote
Old 01-08-2019, 11:19 AM   #2
A32Deuce's Avatar
I hold mine almost 2/3 rds of a second after the light comes on, then hit start. If its warm out it usually starts on the first try. Cold weather usually takes 2 trys.
A32Deuce is offline   Reply With Quote
Old 01-08-2019, 11:28 AM   #3
Do you hold the on button or generator
Old 01-08-2019, 11:33 AM   #4
A32Deuce's Avatar
Hold button down after light comes on for 2/3 min. Then push top start button. Repete if necessary!
Old 01-08-2019, 01:18 PM   #5
Usually Confused Member
emm-dee's Avatar
I must have a different panel than y’all. When I select “Generator” from the main menu on the panel it shows a green Start button. I touch the button for maybe Ĺ second and the center icon shows “priming” for 3-4 seconds, then “starting” followed by “Running” after that. During all this time and after the generator is started, the green “Start” button icon changes to red “Stop” button.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 01-08-2019, 01:26 PM   #6
A32Deuce's Avatar
Push that to shut down only.
Old 01-08-2019, 01:42 PM   #7
A32Deuce's Avatar
That automatic stuff is nice but not like an old fashened rocker switch that you control. That's why you may have to try 3 or 4 times to get to start. Wait till other other operations start acting funky with the panel. Reading other posts on the forum, I like all my manual switches.
Old 01-08-2019, 02:41 PM   #8
emm-dee's Avatar
Thereís still a rocker switch(es) for priming and starting my n the generator.
Old 01-08-2019, 02:42 PM   #9
emm-dee's Avatar
??? Push what to shutdown.
Old 01-08-2019, 02:53 PM   #10
A32Deuce's Avatar
Start stop rocker. That was for someone else. Theirs was a soft button that showed green when it started then turned red. I said to oust to shutdown the genny.
generator
