We have had our home only a short time. Today it started to leak inside. Almost as if someone turned on a faucet until it emptied out. Any ideas? 2019 Forester
I
You don't give much information, but assuming water is coming directly from underneath the AC unit, it may be from a frozen evaporator or the condensate drain is plugged. Run your AC on high to keep the evaporator from freezing.
