Old 05-31-2015, 07:45 AM   #1
Leaking Ice Maker
My ice on 3051s is leaking water down the access panel in front inside. I shut water valve off and ended leak. Any tips before I trek back to dealer again?
lmouhot is offline   Reply With Quote
Old 06-15-2015, 05:54 PM   #2
hello, im sorry i dont have a answer for you, but i have a question for you. where is the shut off valve for the ice maker? i also have a 3051s
mike1911 is offline   Reply With Quote
Old 06-15-2015, 06:17 PM   #3
wesslvm's Avatar
Under the fridge (assuming 4 door fridge like mine) there is a panel, held on with 6 or 8 screws. Don't unscrew them all the way so you can pull them to remove the panel.
Behind there you will be looking at the back of the water heater among other things. You should see the line with the valve and fittings. Push on the valve to close, pull to open.
Wes
2014 Sunseeker 3050S
Honda CRV (TOAD)
wesslvm is offline   Reply With Quote
Old 06-15-2015, 06:20 PM   #4
bubbles's Avatar
The ice maker end cap (left side) should come off and there is an adjuster for the amount of water (size of cubes) to be let into the maker. Maybe it's set for to much water.
Old 06-16-2015, 12:26 PM   #5
thanks for the help with the valve. i have a new 3051s and i can not get my ice maker to work. my valve is open and i have check everything else. how did you get yours to work? thanks for any help.
Old 06-16-2015, 12:44 PM   #6
There is an 'arm' on the icemaker that you pull down. As the water freezes, the arm rises and drops the cubes into the bin.
SkipnTerri is offline   Reply With Quote
Old 06-16-2015, 12:55 PM   #7
yep tried that, moved arm up and down a few times hoping it would trigger a cycle mode. thanks
leak
